Car Audio & Video Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
My car didnt start blowing the starter fuse until the factory radio was taken out and a new radio was put in...why does the starter fuse keep blowing
  • Shekia Rodgers Jun 30, 2020
    Could you tell me how you fixed this problem please!!! Same has happened to my 03 Chevy Tahoe after deck was taken out except it's my pcm1 fuse that keeps blowing out
Patrick
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 25, 2014
Patrick
Contributor
Level 1:
Answers
Questions
Helped
1134
Points
0
Hi I have a 2002 blazer my crank fuse in my truck keeps blowing I put a new fuse in and after a week it blows again what's doing this
Darial Jr Lasaria
Level 3:
  • Master 379 Answers
  • Posted on Jun 01, 2009
Darial Jr Lasaria
Master
Level 3:
Answers
379
Questions
0
Helped
120748
Points
1040
The fuse is always blown due to overload fuse, check the rating of fuse is it the same as the original fuse?.
Mikee
Level 2:
Habit-Forming:
  • Expert 67 Answers
 Mikee
Expert
Level 2:
Habit-Forming:
Answers
67
Questions
0
Helped
35487
Points
223
The new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
  • teresa penaloza
    teresa penaloza Apr 17, 2014
    ive changed the key harness 3 times it keeps blown the engine fuse
I have a 2011 kia Sorento that continues to blow the 40 amp ignition fuse under the hood. Replace the fuse...runs a couple days then blows again. We have replace relays and fuses and checked starter..
Starters will still work when worn but will have increased drag drewing too many amps. which will blow your fuses. before replacing older starter first remove all wire connections shiny clean and replace. make certain starter is tight to block(this is your ground. ) Important to remove ground cable from battery before working on starter.
My fuse keeps blowing under dash when I turn my ignition to start car 2008 Ford Crown Victoria Police
Make sure what fuse it is first. You might also wanna look at any fuses and fusible links under the hood.
2answers
I have a 1999 dodge avenger that keeps blowing the 30amp engine fuse under the hood it only blows the fuse when I crank the ignition checked all the words not sure where to look anymore any suggestion's
If it just keeps blowing it could either be a bad ground somewhere or theres to much power getting pushed to it for some reason when u start it, blowing the fuse
02 Escalade will not start
It will most likely be a poor earth issue, make sure the earth lead between the battery and the body is good and clean and check the one between the body and motor.
Poor earth connections cause excessive current draw and will blow fuses.
Have and older style Poulan rider mower with a 14.5 hp and 42 inch cut. Replaced Battery, starter selenoid, and ignition switch. Now the 30 amp fuse keeps blowing, how come?
disconnect the starter and turn the ignition to see if the fuse blows, if it does not then the starter is grounded, but more then likely there is a stripped/bare wire grounding out somewhere. Hope this helped Tim
7helpful
2answers
THE IGN A FUSE UNDER THE HOOD KEEPS POPPING
You have a serious short. The fuse is keeping you from frying the electrical system. Did you make any changes to the vehicle recently? Is it all stock electrical? If so, check the Ignition relay in the alternate fuse panel. If that does not work, post a reply and I'll help you dig further. Hope this helps
Keep blowing fuses under hood.
REMOVE THE FUSES ONE AT A TIME FOR EACH ITEM ON THE 50 AMP CIRCUIT. I WOULD START WITH THE POWER WINDOW FUSE FIRST. IT WOULD BE THE MOST LIKELY SOURCE OF A HIGH VOLTAGE DRAW. THEN GO ON TO THE WIPERS AND SO FORTH.
FUSE KEEPS BLOWIN (STARTER, IGNITION, & FUEL # 8 FUSE)
you need a new starter I just went through this problem had my starter changed and have not blown any fuses in days....oh and by the way getting to the starter was not and easy task.
No Start
unhook starter solenoid wire and see if fuse still blows if not then starter is shorting out
2helpful
4answers
Ignition fuel starter fuse keeps blowing and it won't start
Hi, I had the same problem with the same fuse, so me and my friend went to a car shop and asked what could make the ign. fuel starter fuse keep blowing. The guy told us {i'm not lying} to go underneath the car and hit the middle of the gas tank a couple times, and move a bunch of wires underneath the hood. So we went back and hit underneath the gas tank a couple of times and moved and shook every wire under the hood. we the replaced the fuse and what do you know, The car started right up. I hope this helps out with your problem if you didn't fix it already!
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
