I ran out of paper. I refilled the paper and my canon multipass f80 said to hit the 'resume' button, so I did. But rather than reset itself the resume button only beeps.
1. Turn off the canon printer. 2. Hold button Resume/Cancel (red triangle in the circle), click on POWER - an indicator light green. 3. Release the button Resume / Cancel keeping POWER. 4. Click Resume/Cancel 2 times, keeping POWER, and then release all the buttons. 5. When the indicator recorded GREEN - click Resume / Cancel 4 times! 6. Turn off the printer POWER button. 7. FINISH
i hope this helpful thank you for using fixya
You need to look at the display (LED window) to see what is displayed. It will give you an error message such as "Clear paper Jam," etc. If nothing is displayed, press the "Resume" key to the left. The light should go off.
Too many things can cause that, paper jams, carriage errors, printhead problems, purge assembly errors, feed roller errors, need more info to be of any help.
On the f80 you need a shop to go to service mode and get the error code and tell you what the problem is. Could be purge assembly, waste ink full, feeder error, printhead error, any number of possible problems.
try a new print head part # QY6-0041-010 I had the same thing happen I replaced it and it works fine I even swaped the ink from the old one to the new one
Hi,I would suggest you to first trying unplugging/ switching off your device for 5 minutes. This restores and refreshes the device. Go for it Let me know if this works, if it doesn’t then I’ll provide some other alternative solution. Thanks
1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 6: Press Power to set data
When your printing? thats the problem? Remove the USB cable then turn off the printer, then turn on it again and plug in the USB cable on the USB port. See what will happen?
