HTC Touch P3450 Smartphone Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY HTC P3400i IS DEAD. Just doesn't turn on.
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger taking the battery out, the red light doesn't come up. I have P3400i. And boy do I regret buying it. Any solutions on how to solve this? You can email me at [email protected] THanks.
Anonymous
Level 2:
  • Expert 502 Answers
  • Posted on Apr 14, 2011
Anonymous
Expert
Level 2:
Answers
502
Questions
0
Helped
1434018
Points
774
There may be a physical issue with your logic board. You can get the part at HTC p3400i Repair and there is a guide that shows you how to put in the part at HTC Repair Guide.
MY HTC P3400I MOBILE ONLY SHOW CHARGING LIGHT AND DOES NOT ANY WORK AND NO SHOW DISPLAY
2helpful
2answers
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger...
Remove the battery then connect the charger without the battery. Then hold down the power button for a few seconds. The red light may come up for a quick second during this process.
Don't remove the charger. After the red light goes off then insert the battery and check if the light turns amber or orange.
Leave it in orange or amber light state for about 2 minutes. After that, try to turn it on. If it turns on then it is resolved. If not then there is a hardware problem with your phone and it needs to be checked at any HTC Service Center.
21helpful
I want bpl wap settings for my windows mobile htc p3400i.
SETTINGS FOR BPL WAP ON HTC P3400
SETTINGS FOR BPL WAP ON HTC P3400I
START>>SETTINGS>>under CONNECTONS tab>>CONNECTIONS>>UNDER ADVANCED tab>>SELECT NETWORK>>select MY ISP there>>then NEW>>
"enter name for these settings:BPLWAP if this exist den BPLWAP2
under MODEM tab create NEW
"enter name for connection:BPLWAP
"selest modem:CELLULAR LINE(GPRS)
tap next
"access pont name:MIZONE
tap next
USERNAME:ur 10 digit mobile no.
PASSWORD:bplmmsc
tap finish
under PROXY SETTINGS tab
mark all two boxes
enter proxy server as "10.0.0.10"
den tap ADVANCED
tap on HTTP
server:10.0.0.10
port:9401
username:ur 10 digit mobile no.
password:bplmmsc
click on ok again ok nd again ok
now below screen will appear saying
programs that automatically connect to the internet shud connect using:select BPLWAP or BPLWAP2
thats it ur done woth settngs
now go tasks der it will show BPLWAP
select MANAGE EXISTING CONNECTIONS
tap and hold on BPLWAP and choose connect
Htc p3400i windows mobile....Battery Charging Problam!
I am also facing the same problem with my O2 XDA mini. It seems to be the problem with the battery/charger. Are you using genuine battery/chargers that came with the phone? I am using a local battery so assume that it has to do something with the battery itself.
May 12, 2009 • Cell Phones
1helpful
2answers
HTC P3400i messaging and hangup problem???????/
try this if it helps
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update backup ur data first
66helpful
6answers
HOW TO INSTALL THEME IN MY HTC P3400I
Jayshree, just do 1 thing. after installing the themes files be sure to keep the respective files in your My Device/Windows folder, were the existing themes files kept.
Now tap on start\setting\today u will get the theme list.
njoy!
5helpful
2answers
Htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
65helpful
8answers
GPRS/MMS settings on HTC P3400i for vodafone postpaid connection
After browsing a lot of sites and experimenting with the settings finally I was able to configure my HTC P3400i with Vodafone Live support without any help from the Vodafone customer care (who were very bad and rude when I called them for getting the setting). The settings is working fine for me in Bangalore. Hope this helps all who bought this phone and struggling for getting the GPRS setting for HTC P3400i.
Below is the step by step instruction:
Step 1
Start->Settings->Connections->Tasks->Add a new modem connection:
Enter a name for the connection:
<give any name>
Select a modem:
Cellular Line(GPRS)
click next
Acess point name:
portalnmms
User name: <blank>
Password: <blank>
Domain:* <blank>
Go to Advanced->TCP/IP
select radio button "Use server-assigned IP address"
Go to Advanced->Servers
select radio buttion "Use server-assigned address"
Step 2
Start->Settings->Connections->Tasks->add proxy setting
Select "This network connects to the Internet"
Select "This network uses a proxy server to connect to the Internet"
Click "Advanced" button
Tap on HTTP
Server: 10.10.1.100 Port:9401
Username: <blank>
Password: <blank>
Domain: <blank>
Tap on WAP
Username: <blank>
Password: <blank>
Domain: <blank>
Step3:
Start->Settings->Connections->Advanced
In "Select which networks are automatically used"-> click the Select Networks
Programs that automatically connect to the Internet should connect using:
Select the Connection name which you configured in Step 1
Programs that automatically connect to a private network should connect using:
Make sure you reboot after doing above change.
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
