I have a 2430DL for 7 years, used to change the IP address of the printer in my XP settings when printer or router was reset. Now I bought a 2nd hand 2430DL because my 2430DL got a fuser error which I couldn't resolve (till today) . This 2nd printer was on DHCP and had IP address 169.254.66.200 (assigned by former owner I think) with subnet mask 255.255.0.0 and for the gateway all zero's. Afaik strange combination. Now I disabled DHCP on the printer (DHCP and BOOTP off) and gave it the for my situation normal and usable address of 192.168.2.8 sm: 255.255.255.0 and the only correct gateway: 192.168.2.1 . No joy and as from start the usually green light near the network cable was irragularly blinking orange. I also assigned the printers mac address in the router with port 192 168.2.8 without result. Printer remained absent in the network .. Printer back to DHCP and again a strange IP address with two zero's subnet mask and zero's for the gateway showed up. I also reset according the printer menu to default settings... and again no result... The ip address might be picked up from somewhere else if it was a wireless connections, but it's wired. Maybe it's a fault in the printer program ? in the network hardware part ? Kind regards from the Netherlands...
The first printer did you replace the fuser???
Second, try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta Bizhub c252 network problem
firqst: DHCP disabled
copier IP adress should be 192.168.x.y
IP Pc must be 192.168.x .z (169.254.xx.xxx is a bad address!! = No-IP address !!)
see my recommendation for the scan on a previous post (http://www.fixya.com/support/t1395654-konica_c252_scanning_address_book_job)
