I changed both fans on this projector because they were making noise (bad bearings). the unit will now power up (Much quiter) the bulb lights up, i can go to the menu and different screens, it seems to be working correctly and then the unit shuts down after about 30 seconds. Then the power button flashes red. it seems to be flashing some sort of code, is there a way to tell an error code from the flashes?
SOURCE: Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
SOURCE: Hi, my Sharp XR-10X bulb was blown and was
reset the lamp timer. unplug it and plug it back in. hold down the enter, down, and menu buttons, then press the power button.
SOURCE: Sharp XR-10X projector. Makes a loud whirring
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
SOURCE: I changed the bulb on my XR-10X projector. When I
Check your air filter, maybe it's all dusty and makes poor air cooling, and you need to reset time (hour) counter in projector menu
Forgot to mention, I did try resetting the bulb timer three or four times, I get the Lamp hours 0000 on the screen. when it shuts down i get a double beep and the power light flashes red
