Our daughter gave us her old Panasonic t.v. However there was no remote, bought one from China, no instruction manual, can't get remote to work, model no. TH-42PV60A can you help please?
0382,0389,0381 are the common codes to check with Panasonic brand TVs.
If you wish to buy a genuine remote control, contact the authorized service center, or authorized dealer. If you wish to buy a universal remote control, you should first make sure about the number of digits in the set-up code, for the device you have. For example: some brand sets will have four digits in its set-up code, some of them will have three digits, and so on. There are devices that need even a single digit or 2 digit or 5 digit codes. Check how many digits code your device has to synchronize with. It is so easy to check, just enter any digit from your remote control, when the set asks for code. See, if you're entering Zeros, repeatedly, when the set asks code, and the set allows you to enter only 3 Zeros, means, the set-up code to your set should have Three Digits one.
Now visit the sites I've linked here. Both the sites have set-up code list, and set-up procedure to many popular brand remote controls. Check it, and find out which brand remote control have setup codes to your device, and buy that one according to availability. Keep in mind; when you buy a universal remote control, it will have setup code list, and setup procedure along with its catalogue. Never accept a remote control, with out this document. See the sites by "Mosaic" view; which will make surf easy.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Testimonial: "Thank you for your detailed answer to my problem ."
SOURCE: Jensen JER321 3-Device Universal Remote
coding:
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press
and release the ON-OFF key repeatedly until your component turns off.
Wait four seconds between each keypress. Each time you press the ON-OFF
key, the illuminated ON-OFF key blinks and the next code in the list is
sent. This process continues until all of the codes in the Code lists
have been searched. If your component turns off, you have found the
correct code.
7.Once you have found the correct code, you must save
the new code by pressing and releasing the STOP key. The illuminated
ON-OFF key turns off. You must press the STOP key to save the code or
the correct code will not be stored.
SOURCE: setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
SOURCE: Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
