Sony KV-27S42 27" TV Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black screen..no sound Exactly the same as the other post. I read that it could be the high voltage PS and flyback circuit.
Darial Jr Lasaria
Level 3:
  • Master 379 Answers
  • Posted on Jun 01, 2009
Darial Jr Lasaria
Master
Level 3:
Answers
379
Questions
0
Helped
120800
Points
1040
Try to remove the vertical IC sometimes it become Shorted causing the B+ to drop. after removing try to switch on back check the B+ if ok and the LED not blinking then change the vertical IC.
How can i solve error my lcd Panasonic model TH L32C4M Red led are blinking 3 times
https://www.youtube.com/watch?v=IrC77AnKF4g
Your Panasonic TV's power light blinks when you power it off or on, or put it in Stand-by mode. ... Press the "Power" button again to set the TV to operate in Stand-by mode. The Power LED Indicator should illuminate as a solid red color. Press the "Power" button on the remote control to bring the TV out of Stand-by mode.
https://itstillworks.com/12594583/how-to-troubleshoot-the-blinking-power-light-on-a-panasonic-tv
https://www.youtube.com/watch?v=kJs4TpaXfX4
1helpful
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
4helpful
2answers
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
3helpful
POWER STAND-BY LIGHT KEEPS BLINKING
part# 191002393 is the thermal fuse.Located on lamp housing.
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Sony shuts off after being turned on, stand by/timer light blinks
The blinking should be in a pattern of a count, pause, count. That is an indication of the problem circuit. Can you post that count please? That info will allow me to give you possible defective parts and costs for the repair.
Thanks,
Dan
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
