Hello
Not to much information from you . Here is a E-Machine assembly for the motherboard .
The power switch is a 2-wire connection to the Motherboard. The 2 pins on the motherboard it connects to will be labeled something like PW. The polarity on it doesn't matter. There will also be a power LED connection. Usually those wires are green and black. Green is positive. There's also a hard drive activity LED with (usually) red and black wires. Red is positive. Hopefully that polarity will be marked on the motherboard. If not, try it one way and if the LED doesn't light up, try it the other way. The power (green) LED should be on whenever the PC is on. The hard drive (red) LED will be on whenever the drive is being accessed.
There might be pins on the motherboard for reset. Some computers don't have a reset button. In that case you wouldn't connect anything to it. If your case does have a reset button then connect the wires to the reset pins on the motherboard. Polarity doesn't matter for that.
Hope this helps
