SOURCE: Mobile phone as a modem
1) go to www.samsung.com to downlaod the driver and install
http://www.samsung.com/sg/support/download/supportDown.do?group=mobilephone&type=mobilephone&subtype=businesses&model_nm=SGH-D880&language=&cate_type=all&dType=D&mType=SW&vType=R&prd_ia_cd=01011300&acc_ia_fl=&disp_nm=SGH-D880
2) Connect the D880 with your PC using usb cable
now it will report that find a new hardware you can see from computer management that you have a new modem.
If you can not get it do remember to check if you had set your D880 to modem mode. (In phone setting , personal computer connetion, select modem mode.)
3) if it still not work leave me a message at my blog:
nuclearphysics.spaces.live.com
SOURCE: how to connect samsung e251 to pc as a internet modem bluetooth
u need to purchase bluetooth doggle nd install software of bluetooth in pc then connect it ur work is done...
SOURCE: samsung mobile phone > GT-C3053 (GT-C3053) user
samsung GT-C3053 switch on and it shows greetiing msg again and again. it did not go next step
SOURCE: can samsung champ gt c3303
who can use internet in my cellphone
my cell is SAMSUNG Model :- GT-C3303
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
Procedure
6. Hit OK and exit.
Error 619 solved
2.8 Hit Finish
