2000 bug
There's an electronic actuator inside the trunk door. The actuator opens the trunk lid when you press either the remote keyless entry or the inside trunk release. If the electronic actuator fails it usually fails in the trunk open mode which will not allow you to close the trunk lid. You can either remove the actuator and take the car to the VW dealer, or buy a new actuator and replace it yourself. It's a tough fix, but not impossible for the mechanically inclined.
SOURCE: 2000 bug rear trunk wont close
try wd40 on the lock and cable. it could be a kinked cable holding the lock open. lock may be worn out. replce with new.
The valet lockout switch is closed.
Power is supplied through the following components to the now-grounded CKT 1344 (LT BLU):
The RADIO/PHONE fuse
CKT 40 (ORN)
The coil of the rear compartment lid release relay
The relay coil energizes and closes the relay contacts.
Power is supplied from the CONVENIENCE fuse through the following components:
CKT 2040 (ORN)
The now-closed relay contacts
CKT 56 (BLK/WHT)
The rear compartment lid release solenoid
The solenoid energizes and the rear compartment lid latch assembly releases the rear compartment lid.
Did you perform the rear compartment lid release system check?
Go to Rear Compartment Lid Release System Check
Have you tried to use the key to actuate the latch open or is the latch open already and failing to latch?
