I have a brand new(never used) Karcher 2,500 PSI power washer with a 5 HP Honda engine that sat in my shed for a couple of years(unused). I finally got around to trying to use it, added oil, gas, pulled the choke closed, released the pressure in the hose and pulled the cord about a hundred times. It just won't start. I even pulled the spark plug, and sprayed starting fluid(ether) into the combustion chamber and it wouldn't even turn over once. Any ideas?
One thing I saw one thing that you did not list did you you turn the start switch on its usually on the right side of the motor, If not switch will ground out coil and no spark is received.
