HP LaserJet 3055 All-In-One Printer Logo
A
Anonymous Posted on Dec 14, 2017
Hp laserjet 3055 paper jams at toner cartridge
Printouts started to come out with vertical blanks. Ok...needs new toner. Put in new toner cartridge. Now the paper jams right where it appears to hit the toner cartridge. Put old cartridge back in see if it jams. Yes, it jams. we have lots of pages still in memory that I don't want to lose so how to solve?
5 Related Answers
Anonymous
  • Posted on Nov 10, 2007
SOURCE: HP Laserjet 1100
Had the same problem with my HP 1100 printer. It was a faulty laser unit. Replaced the laser unit and the printer was fine.
A
Anonymous
  • Posted on Mar 17, 2009
SOURCE: HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
xptareq2000
Tareq Bin Mostaq Mostaq
  • 1449 Answers
  • Posted on Jun 28, 2009
SOURCE: HOW TO CLEAR PAPER JAM HP LASERJET 3055?
please you see your copier paper feed sensor is open or delivery sensor is open or broken
Anonymous
  • Posted on Sep 16, 2009
SOURCE: Paper jam message on HP C4599 when there is no jam
I had the same problem. I called HP and went through the steps they had asked me to go through to fix it. It took about an hour. Nothing worked. They offered me a replacement. I said no, and they offered me a $150 gift card for Staples.
Michel Smith
  • 1218 Answers
  • Posted on Oct 21, 2010
SOURCE: My HP 2420 had a paper jam. I played around with
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
2answers
Hp laserjet 3055 printer print blank pages how solve it`
1) Check the toner cartridge: Is it new? Is any protective tape or cover to be removed actually removed before installation? Is there any other obstruction preventing the toner from coming out?
2) Check with the printer itself: the drum to pick up the toner may not be charged each time.
Paper jam in hp 3055
Remove the cartridge check paper jam, remove re install cartridge..
2answers
My hp laserjet printer 3055 printing out put is blank sheet is coming
This can be caused by a number of reasons however it is mostly caused by the toner cartridge missing a small spring on one end. Try replacing toner cartridge first.
Paper jammed in fuser
Pull the toner cartridge out and leave the door open to relieve the pressure on the rollers.
Grasp the paper close to the fuser and pull gently and steady.
1helpful
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
1helpful
2answers
Clear paper jam in top feeder of HP 3055
IT HAPPENED TO ME, I HAD TO TAKE HP ONLINE HELP, BUT ACTUALLY U WILL HAVE TO OPEN THE WHOLE AFD LIKE LITERALLY UNSCREW IT OPEN CAREFULLY AND THE ROLLERS AND THEN U MIGHT MANAGE TO TAKE OUT THE JAMMED PAPER
2helpful
3answers
2200d hp laserjet
The green flashing light lets you know that the machine is recieving data. This is completely normal, however, the red (Attention) light can mean several things. There can be a door open, missing toner cartridge, out of paper, or paper jam. In this cause it is probably the toner cartridge. Typically on these machines there is an Orange or Green tab on the side of the toner cartridge that needs to be pulled to fully engage the cartridge. You may want to make sure this has been pulled and the cartridge has been properly seated.
Hope this helps...let me know if you need any further assistance
V
k24674
Grand Canyon Tech
Grand Canyon Tech
