Screen will not go past raise presser foot. In the past it was the sensor where you run thread around top area and takes months to be fixed in a shop. Can I fix myself?
SOURCE: The top thread will not grab the bobbin thread to complete a stitch.
its common, but easy to fix,,,ok......first things first, 1. bobbin in bobbin case correctly 2. machine threaded correctly 3. tension set around 3-4 upper 4. when was the last time machine was serviced
SOURCE: bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
