Printer fan runs all the time. even when I am not printing. It runs form I turn the printer off until I turn it off. Any suggestions?
SOURCE: stopped printing PDFs and Web pages
those your printer support wireless printing? if not try to check if it is bluetooth capable
SOURCE: All error lights blinking and fan running but won't print...
Yes Mr. Guest and Mr SwT,
Replace the fuser assembly unit.
Definitely the fuser got problem. This can be confirm by pressing the Go button and only the Toner LED will light up.
What had happen was right after the power blackout the fuser has fused together both rollers (heating drum and rubber roller) where the paper pass through in between the rollers. Since there was a power blackout, the printer fan has stop functioning and the heat was unable to disperse out from the printer. Suggest to improve on design to disperse heat using aluminium cage in case of power blackout.
Who ever has a Brother HL-2040 should definitely use together with a UPS.
chekamal
SOURCE: Can't print multiple copies
On your Brother's drop- down menu, left click on PRINTING PREFERENCES . On the BASIC tab, choose the number of prints in the COPIES box, then left click on APPLY. If that does not work, go into PROPERTIES, left click on the SECURITY tab, and check that you have authorization to run multiple prints. Also, check your PRINT SPOOLING mode to make sure it is activated, and check authorizations in OFFICE 2007- it may be set to restrict multiple color pints.
SOURCE: Printer would not run
open the front door thenremove ik cartridge then check there is not any paper jam.then restart the printer.
SOURCE: Printer Won't Print
Follow the link below for what the lights on the machine mean. I know that if your alarm and data light are on it means the toner is empty, and you wont be able to print, you would need to replace the toner cartridge, please follow the link below.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000070/faq000170_012.html?reg=us&c=ca&lang=en&prod=hl1440_all
