2003 Volkswagen Passat Logo
Posted on May 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Interior trim panel removal instruction
Trying to remove left rear interior door panel on a 2003 VW Passat.
  • Anonymous Mar 16, 2014
    removal of interior door trim
Anonymous
Level 3:
  • Master 316 Answers
  • Posted on May 31, 2009
Anonymous
Master
Level 3:
Answers
316
Questions
Helped
203081
Points
1462
Normal 0 . Disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
If you don't have power windows you will have to remove the manual window crank. It is held in place by a clip on the back side of the base. To remove the clip, you will need a small hook (kind of like a knitting needle). Put the hook in behind the base, and grab the clip and pull it off. To replace it, slide the clip back on the window crank, and snap it back on the door.
Replacing quarter glass on left side on 2005 pontiac gto
Remove the door opening weather-strip. Refer to Door Opening Weatherstrip Replacement in Doors.
Remove side sill trim plate. Refer to Door Sill Plate Replacement in Interior Trim.
Remove the lower quarter panel trim. Refer to Rear Quarter Trim Panel Replacement in Interior Trim.
Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement in Interior Trim.
Remove the quarter upper trim panel. Refer to Rear Quarter Upper Trim Panel Replacement in Interior Trim.
Remove the center pillar outer applique. Refer to Center Pillar Applique Replacement in Exterior Trim.
Remove the roof drip molding. Refer to Body Side Roof Drip Molding Replacement in Exterior Trim.
Important: It is necessary to use new nuts when reinstalling the quarter window.
Remove the nine quarter window nuts (1), securing the quarter window assembly (2) to the body opening.
Caution: When working with any type of glass or sheet metal with exposed or rough edges, wear approved safety glasses and gloves in order to reduce the chance of personal injury.
Important: When removing the quarter window from the body opening make sure that the attaching pins are clear of the outer body.
Remove the quarter window (2) from the body opening.
Remove the rear seat cushion. Refer to Rear Seat Cushion Replacement in Seats.
Remove the rear seat back. Refer to Rear Seat Back Replacement in Seats.
Remove the door sill plate. Refer to Door Sill Plate Replacement .
Remove the 3 quarter trim panel retaining screws (1).
Starting at the lower edge of the trim panel and moving alternately clockwise and counterclockwise, pull outward on the trim panel to disengage the eight rear quarter trim panel attaching clips (2).
Remove the quarter trim panel from the vehicle.
Remove the 4 radio speaker grille speed clips (1), securing the speaker grille.
Remove the speaker grille (2).
Remove the rear quarter trim panel insulator (1), from the back of the quarter trim assembly (2).
Remove 7 rear quarter trim panel armrest retaining clips (1).
Remove 7 rear quarter trim panel armrest retaining nuts (2).
Gently pry the quarter trim panel armrest insert assembly (3), away from the rear quarter trim panel and remove.
You mite look for a video on youtube !
1helpful
2answers
How do i open the interior fusebox in my honda hrv 2000 model. Thankyou.
Kathryn, Not familiar with Honda hrv, did you mean CRV. There will be a small trim door to remove, lower dash by drivers left knee to access interior fuse panel.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Fuse Box layout on 2000 CRV Honda Tech
Interior Fuse Box Location 1997 2001 Honda CR 2000 Honda CR EX 2 0L 4 Cyl
Thread What are these Definitions
1helpful
Where are drains located on a 2003 chevrolet impala sunroof?
They go down inside front A pillar an inside rear D pillar . To get at them you need to take trim off an the headliner down .
Sunroof Housing Rear Drain Hose Replacement (Impala)
Remove the headliner. Refer to Headlining Trim Panel Replacement in Interior Trim. Remove the rear quarter lower trim panel. Refer to Rear Quarter Lower Trim Panel Replacement in Interior Trim. Disconnect the rear sunroof drain hose from the sunroof module rear spigot. Remove the tape from the rear sunroof drain hose tube.
Disconnect the rear sunroof drain hose from the rear sunroof drain hose tube. Remove the rear sunroof drain hose tube from the upper retainer clip. Remove the rear sunroof drain hose from the rear pillar
The front is simalier .
Where do I add washer fluid for rear window wiper on a 2000 blazer
Same place you fill for the front washer fluid ! Your fronts work but not the rear ? There are to washer pump motors on the washer fluid bottle , one for the front an one for the back . Rubber hose goes all the way to the back . If that hose has failed ,to replace it you basically have to pull out your vehicles interior .
Rear Window Washer Hose Replacement - Pump to Endgate
Removal Procedure
  1. Remove the left front seat. Refer to Bucket Seat Replacement in Seats.
  2. Remove the rear seat. Refer to Rear Seat Replacement in Seats.
  3. Remove the endgate/liftgate door sill plate. Refer to Rear Floor Rear Trim Plate Replacement or Liftgate Door Sill Plate Replacement in Interior Trim.
  4. Remove the left front and left rear door sill plates. Refer to Door Sill Plate Replacement in Interior Trim.
  5. Remove the left body side trim panel. Refer to Body Side Trim Panel Replacement in Interior Trim.
  6. Remove the left hinge pillar trim panel. Refer to Body Hinge Pillar Trim Panel Replacement - Left Side in Interior Trim.
  7. Fold over the left side of the carpet to allow access to the body harness. Refer to Front Floor Mat/Carpet Replacement and Rear Floor Panel Carpet Replacement in Interior Trim.
Disconnect the washer hose connection (1) from the body harness (2) at the endgate. Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement in Engine Controls.
Disconnect the hose (1) from the rear washer pump. Install a plug to the rear washer pump nozzle to prevent washer fluid loss. Push the hose grommet (2) in through the bulkhead.
Pull the washer hose (1) into the vehicle though the bulkhead. Cut the old washer hose off where it enters the body wiring harness (2). Remove the hose end from the vehicle
Or it could be the pump , they go bad . switch the hoses from one pump to the other an see if you get washer fluid at the back ,if you do the pump is bad ,if not the hose or the spray nozzle is clogged . You probably will need to pull the washer fluid bottle to see both pumps
How do I remove the driver side door panel on a 1994 Lincoln Mark VIII
Remove mirror mount cover assembly.
Remove inside door handle cup (22634).
Remove door lock control bezel.
Remove window control bezel.
Remove interior lamp lens.
Remove screw from interior lamp assembly body.
Remove screw from window control bezel opening.
Disconnect mirror, lock switches and memory seat on driver side from bezels and wire harness.
Disconnect window switches from window bezel and wire harness.
Lift front door trim panel (23942) vertically, out of weatherstrip and over lock rod.
Disconnect interior lamp (13776) from wire harness.
Remove front and rear door trim retention hooks into door inner panel.
To install, reverse Removal procedure, paying special attention when inserting inner door trim into weatherstrip. Rock inner door trim into weatherstrip and push downward until lower trim belt character ditch lines up with score mark on inner door panel.
9helpful
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
Door panel
go to http://forums.vwvortex.com/zerothread?id=1015107 This is a three part article that includes instructions for removing and re-installing the interior metal panel for front doors on jettas.
7helpful
Side mirror of 2005 ford explorer
Exterior Mirror Removal and Installation
All vehicles
  1. NOTE: Left side exterior mirror shown, right side similar.
    Remove the interior door trim panel. For additional information, refer to Section 501-05 .
Front Door Trim Panel Removal and Installation
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the inside door handle bezel from the trim panel.
  1. Remove the window switch assembly.
  1. Disconnect the window switch and power door lock electrical connectors.
  1. Remove the upper trim panel screw at the window switch opening.
  1. Remove the lower trim panel screws.
  1. s2n~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the door trim panel, do not pull directly outward for this step.
    Lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  1. Disconnect the power mirror electrical connector.
  1. Remove the trim panel.
  1. Remove the weather shield.
Vehicles with power, heated or approach lamp equipped exterior mirrors
  1. Disconnect the electrical connector.
All vehicles
  1. Remove the bolts.
  1. Remove the exterior rear view mirror (17682).
9helpful
How to remove the door panel on a 96 Ford Thunderbird?
Carefully pull front door trim panel finish panel away from front door trim panel.
Disconnect wires from front door lock switches, outside rear view mirror controls and window regulator control switches, if equipped. Remove front door trim panel finish panel.
Rotate top of front door trim panel away from front door and lift bottom hooks from front door.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
