My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
There is a door sensor in the door frame of your microwave that tells the microwave if the door is open or shut. That sensor is not working for some reason. The sensor is near the latch mechanism and is made of plastic and has probably broken and needs to be replaced. I would take it to a small appliance repair shop. Microwaves are nothing to fool with if you do not know what you are doing.
The model number 721.80032 is a partial model number; it indicates the build series. I found the Kenmore microwave, 721.80032700. The final 3 digits indicate the panel color and similar details.
Assuming the microwave was installed properly, it should work as a hood fan. Press the touch pad with the fan icon (underneath it says Hi/Low/Off) to get the desired fan speed. The icon is on the lower left of the control panel; it's below the Cook Time button and to the left of the Light button.
If you wish to get some details about microwave oven's working and repair ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
With the full model number, chances are we could have helped you more.If the
cooktop lights recently failed, it may need circuit board
repair.
Or it may be a failed hood TCO.
You can find links to helpful exploded view diagrams and part ordering help
here.
I recommend that you bookmark that link to your favorites.
I need the compete and full model number. It is more than just 5 numbers.
