Motorola Mobility W510  Mobile Phone Logo
Posted on May 31, 2009
How do i download pictures from my mobile phone to the computer
I have a usb that belongs to my motorola w510 and i don't know how to download my pictures to the computer. Can you explain. I am not able to download the pictures I take with the W510 onto a mac running OS10
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
264
Points
I cant sync photos fro my pc to my motorola phone
1helpful
I'm getting a boot loader error, "ph sig err 35:02:" How do I fix this?
your phone is stuck in bootloader mode and needs to be reflashed if your still under warranty then try and just return it for a new one. If not then you"ll have to download a backup of either a w490 or w510. Both are free.
w490 here:http://www.opera.com/mobile/download/motorola/w490/
w510 here:http://www.opera.com/mobile/download/motorola/w510/
How to openline W510
There can be many ways to Unlock your phone.
As far as i know unlocking by codes is the simple and safest way.unlock using software delete some information in memory i unlock my phone using codes ,i got codes from http://www.mobile-unlocker.com/motorola-moto-w510/rs2wp9/
I used codes to unlock my cell phone. i had my unlock code and my phone was unlocked.
you need to specify the phone model and network provider
How can i pass music from my computer to my new motorola w510
There are several ways you can send music from your computer to your new phone.
You could use your phone cable, or a memory card reader, or transferring via bluetooth, or using a pC suite. It all depends on which method you find convenient to use.
Take care.
How do i customize ring tones? (i.e. use my own music, etc.)?
Please find steps to customize ringtones.
Note: in order to be able to use this method one has to have two Motorola phones: the W510 and an older one that isn't ringtone-locked (I tried a V190 and and RAZR V3 and both worked).
First create a backup directory on your drive and call it something like "Original Motorola W510 audio directory". The name doesn't really matter as long as you can find it later if you ever need those files again. Next install the ringtones you want to have on your W510 to the old uncrippled phone.
Then follow these steps:
Step 1 - Connect the W510 to your computer via USB or Bluetooth
Step 2 - Fire up P2K (latest version)
Step 3 - In the right pane navigate to P2k:/c/mobile/audio/ on the W510; in the left pane navigate to the backup directory you just created on your hard drive. It will be empty.
Step 4 - Select all the files in P2k:/c/mobile/audio/, right-click and select "copy", the files will be automatically pasted in your backup directory.
Step 5 - Delete all the files in P2k:/c/mobile/audio/. Once this is done the "audio" directory will have vanished so it's possible that P2K will crash, this is not a problem.
Step 6 - Create a new directory on your disk, name doesn't matter. Unplug the W510 from the computer and reboot it (the phone), then close P2K (if it hasn't crashed already) and plug the older Motorola phone into the computer, wait for the computer to recognize the new phone, then restart P2K. On the right pane navigate to the old phone's audio directory (same location as on the W510), on the left go to the new directory you have just created.
Step 7 - use the method described in Step 4 to copy all the files in the audio directory to your hard disk. *Do not erase any files in the old phone's audio directory*
Shut P2K down and unplug the old phone from the computer. Plug in the W510 and wait for the computer to recognize it. Once this is done fire up P2K once more.
Step 8 - Remember that the audio directory on the W510 is gone, so you can't navigate directly to it, you need to create it first. In the right pane go to /c/mobile/ and select "New Folder" from the menu at the bottom of the pane. Name the new folder "audio" and navigate to it.
Step 8 - In the left pane navigate to the new directory on your hard drive that contains the audio files from the old phone.
Step 9 - Copy all those audio files to the new audio folder you just created on the W510.
Step 10 - That's it, your W510 now contains every single ringtone that was on your old phone and all of them now have the "apply" option enabled so the W510 will now accept any of those sounds as a ringtone.
Unfortunately the W510 still won't accept sounds from any other source than the old phone but as long as you're able to get those those sounds (inclding custom sounds) to register as ringtones on the old phone you'll be able to transfer them to the W510 using the method described above. It's a little tedious but there ain't no such thing as a free lunch is there
Thanks
S
I have at&t server, and i just got an unlocked Motorola W510, i can text but i can not send or recieve picture messages. Also i can not get on the web from my phone to buy ring tones. What should i do?
No problem. Simply call your operato and request to enable internet settings in your mobile. They will automatically do the required settings. After that you switch off your mobile phone and then switch it on. You will be able to access internet on your mobile and for bying ringtones go to the homepage and select the tone you want to buy. It will be downloaded to your mobile..
Thanks,
With regards,
Lakshay
Unlocked Motorola phone can't do multimedia messages
i have the same problem but i cant send or recieve pictures,audio files,ect. and also i constantly have a message icon that will not go away
2helpful
HI friend ,
this is a sure shot solution for your issue.
Things you need:
USB cable=1
In case of memory card -> memory card reader would be helpful .
Connect the other end of the USB cable to the PC.
Open up MY computer->open removable disk->open files and folders-> select the files you want to save on your PC-> cut/copy,paste it into any folder of My documents or any other folder on your PC.
This will surely solve your issue!!!
Thank you for giving me a chance to help you out:):):)
And please vote/rate me so that I can improve myself and be of more help to you:):):)
Prasanth83:):)
Motorola w510 will not turn on i need numbers and pics off the pn
Hey try to connect the phone to the USB cable that came with it & your computer. Make sure that it is completely charged in any case first though you may have forgot to charge it.
2answers
W510 service manual
how can i get the cd installer of my motorola w510? thers not available in the market. bcoz my computer not recognice my phone.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
