Need to know the wiring diagram for a 1.5 hp 2 speed balboa motor.There are 4 wires coming to engine and a blue wire already in motor.need to know what color to hook to L1 and L2 and the A terminal
CAUTION: Electrical work and repairs can be dangerous, especially around water. There is a risk of shock or electrocution, which could result in serious injury or death. We strongly advise that hot tub electrical wiring be referred to a licensed electrician. Local code requirements for wiring vary and may differ from the educational examples on this web site. The local code regulations must be followed, with permits and inspections obtained. The installer should read and follow the hot tub owner's manual and associated electrical component owner's manuals and instructions.
Try this link: file:///C:/Documents%20and%20Settings/Gil/My%20Documents/Troubleshooting%20&%20Service%20Manual%20230V.pdf
SOURCE: Switch missing on 10 hp Tecumseh engine that is installed on a
First I have never owned a Tecumseh Tiller. How that got attached to me I don't know. I do have a 10 Hp Tecumseh Engine that I wish to check out if it is good or not before I buy a switch. It has a Brown wire that goes to the low oil shut down sender. It also has a green wire and a black wire. All I need to know is which wires do I need to put together so I can check if the engine is firing or not.
SOURCE: tecumseh 8 hp tvm220
it is a standard magneto fired engine --- go on line and google up magneto
SOURCE: Hi,The problem is I bought a used Dayton 2Z802C
call grainger's technical service department they can help and fax you a wiring diagram
SOURCE: i am looking for a wiring diagram on a vanguard
i will try to help. here is a website http://www.cartpartsplus.com/club-car-engine-upgrade-kit-18-hp.html and the forum http://forums.cartpartsplus.com/index.php. the forum will be your best bet.
