check that the switch on the power supply has not been accidentally bumped.
It should be on the - side... not the o side.
There could be a variety of other problems including the power switch.
Possible reasons a PC will not power up:
Failed Power Button.
Power strip breaker tripped - are there other items plugged in that work?
Failed memory Module.
Failed CPU.
Failed CPU Cooling fan.
Failed power supply.
You will need to test each item with a Digital Multi Meter (DMM) and verify 12VDC at each item. CPU and Memory can only be tested externally by a shop with a reader.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
