Installed a xtreme sound 5.1 sound card with drivers but am only getting sound from left, right and sub woofer. when I test them from mixer they all work (ping) but will not play sounds in media player etc...
A 5.1 sound card will give output in all channels only if the audio being played is also 5.1.
Normally out of 6 Speakers only 2 front and sub woofer will play sound, in case of a DVD or Movie which has 5.1 encoding, all 5 will come alive.
Also, Dolby Prologic II and Dolby Digital will convert a 2 channel input into psudo 5.1 enviornment but Dolby has to be in hardware or speakers or Receiver.
SOURCE: front right speaker is not working
This may sound obvious, but have you plugged in all the plugs?a 4-channel sound system has two plugs that plug into the sound card.One is for the front speakers and part of the subwoofer, the other is the rear speakers and the other part of the subwoofer. AC97 audio normally supports only 2-channel.s your sound on-board?how many sockets does it have.A common AC97 normally has a green plug (for 2.1 speakers), a blue one for line in and a red one for a mic.A four-channel one will have a black socket for the other two speakers.and 5.1 has a yellow socket for the 5th speaker and woofer.
If your AC97 audio does not have the black socket, then you will need to buy a special card, like the Sound blaster 4.1 Digital (around £20-30).Or, if you want a 5.1 card, the Creative Audigy is considered the best, as the Audigy 2 is still expensive, and there are cheaper cards for 4.1.
Hopefully this should sort out the problem.I also have Creative Inspire M4500 4.1 speakers, and they have 2 plugs.
SOURCE: Creativr Gigworks S750 Subwoffer intermittent sound
The S750 system is a great sounding one but unfortunatly like many similar systems all the amplifiers and power supplies are housed inside the sub box. This means they suffer badly from heat and vibration problems (they cook themselves or shake themselves apart). I have fixed a few S750 systems in the past but due to their complexity it's not for the faint hearted.
SOURCE: i've got crative inspire t7900 not workin
You can hear music and sound when you test your audio and also the Windows startup and shutdown even sounds. But you can't hear any music when you play it in Windows Media Player or the videos on youtube because Windows Media Player needs some codecs installed and you don't have those installed.
You can download and install this Media Player codec pack from Microsoft.
Hope that helps,
Regards,
Raspal
SOURCE: Stopped working. I-trigue 3400
The stereo -jackbus is broken if your speakers won't work and your headphones are fine. The stereo jackplug holds a little switch at the back, which moves sideways if you connect headphones.
Solution is very carefully opening back end of stereo connector bus and reassembling the switch
