Toshiba 57H83 57" Rear Projection HDTV Logo
M
Mike Posted on Jan 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Used to be that when you turn on the TV the red on light would be solid and TV worked - now red on light is flashing and no picture or sound??
Kenneth Lee Sr.
Level 3:
  • Master 597 Answers
  • Posted on Feb 04, 2014
Kenneth Lee Sr.
Master
Level 3:
Answers
597
Questions
10
Helped
82822
Points
1207
COUNT THE NUMBER OF FLASHES..CONTACT TOSHIBA TECH SUPPORT
3 Related Answers
A
Anonymous
  • Posted on Oct 26, 2007
SOURCE: Flashing Red Power Light
i had to replace the power supply
Anonymous
  • Posted on Dec 19, 2007
SOURCE: TV on/off light keeps blinking red light/no sound or picture on screen
Here's a solution that I received from an TV expert in another website: "This sounds like a power supply problem. i have seen it several time on your model. i would not keep trying to turn it on it might damage something else in the tv. the reason it is shutting off is because the power supply is putting out too much voltage. a repair cost will range around 300-400. this is a great model and well worth a repair. here is a web site that might help you in finding a repairman.
http://www.nesda.com/locator/state_search.php." <-- $300-$400 is too much! But throwing away a 300lbs TV will cost a lot of $$$ for the towing and dumping too. I haven't decide what to do yet.
Anonymous
  • 1067 Answers
  • Posted on Jan 29, 2008
SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
Loud buzzing sound from tv with no picture
It sounds as though your SMPS is seriously faulty and normally one can buy a kit to correct the problem if you are a TV engineer, however there could also be many other reason for the condition that you describe its almost impossible to guess correctly, it really needs a qualified engineer to assess the problem along with he or she having the set with them.
Samsung ln46c530 lost picture, now won't turn on. Indicator light turns on solid red when on, flashes five times when shut off
The fault is with its main board itself. Troubleshooting to this board is not an easy work to a user can do. It will be best to contact any service technician. google.com/+GopakumarGopalan
2answers
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
TV turns on, only voice,no picture,red light will flash, no click
You may have to resolder your vertical IC. This seems to be a common occurence for many Sony TVs. This is my first diagnosis when I get one of these in. But, yes there could be a bad ground almost anywhere. You will need to pull the board out and resolder any IC mounted on heatsinks and any large power resistor and resolder the pins connecting the flyback transformer to the board. This tip is always the first place to look for in repair. Good Luck and be mighty careful. Thanks for asking!
2answers
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
LG RU-44SZ63D
Hi there
This could possibly be your Ballast ( lamp's powersupply ) that is faulty.
It will either need repair or replacement.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
