Question about Dell PowerEdge T300 Server
I have a poweredge t300 server and am having an issues connecting to certain website which I can log on to using a different computer not connected to the server which leads me to believe it has to do
I can connect to the website www.gpsheroes.biz off my home laptop or even my cell phone but the work computer connected to the server will not allow me to connect to the same website. Is some sort of issue with the server settings? This is only happening with that particular website all others work just fine.
    Sergeant:
    Novelist:
  • 143 Answers
Sounds like you're running into a security limitation. Firewall, etc... Corporate software is perhaps blocking the request for that site.
Honestly? I'm not really clear on the situation as your question is poorly constructed.
I'm guessing this is too old to be an issue at this point, however.
Posted on Jun 13, 2015
SOURCE:
SOURCE: Dell PowerEdge 840
Look in Bios setup for OS Install mode setting. If it is enabled, it restricts the RAM to 256MB. Change the setting to off and it will sense the total RAM
Posted on Dec 09, 2007
  • 7 Answers
SOURCE: Adding a second processor to my 2600 server
I hope that you fixed your problem without troubles by now, but if you still have not, I can help. I added a second xeon processor to my Dell PowerEdge 2600 a couple of years ago.
Lay the server on its left side then loosen the three thumbscrews on the right front side and "slap" the cover off backwards.
You should have by now identified the current processor by running cpuid software that I think comes from Intel's website in order to buy an identical cpu. That was the hardest part, finding an identical one still for sale. If I remember the Poweredge 2600 could only use xeon processors with only up to 512 kb of cache or someother small amount and are not that available still new in the box.
You also have to get two identical voltage regulator modules (vrm). I was not able to get a second one for some reason and just bought two identical ones specifically for the xeon processors that I was using. Be sure to do your homework on this. MATCHING cpu's and MATCHING vrm's.
That's it. Each processor has two cores and you should see all four after you boot.
Another thing to think about would be setting the processor afinity to run your most intensive process to all four cores while only letting most applications to only use the first core.
I hope this helps if you haven't already had any success.
Posted on Jan 21, 2008
  • 7 Answers
SOURCE: dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
Posted on Mar 17, 2008
SOURCE: Problem in reboot the server in domain
We are having one server poweredge 2900 which was open and did some preventive maintenance for dust and other diet. But after the preventive maintenance, we try to switch on the server but the hard disk drives cannot display at the same time.
Posted on Mar 16, 2009
bob_computer
  • 3153 Answers
SOURCE: I'm trying to install Microsoft Server2003 on a
Another common way around installation is to copy the whole contents of the CD / DVD to a hard drive.
There are a few methods.
My proffered is to make a bootable flash drive on another machine with known working capabilities that will bot into either an XP-pre installation scenario or a Dos based one.
From there it is often possible to start the installation or even copy the required files to a drive on a machine.
Advantage of copying the files is that the CD / DVD would never be needed to add additional component as they are stored on the machine itself.
That also speeds up installation dramatically.
Bios consideration mus be taken into account when booting from flash drives.
Proper external Hard drives are another viable option
Posted on Sep 08, 2009
Testimonial: "I didn't have a Flash drive available but I changed the CD drive (laptop cd drive) and it worked. Seems like the other one didn't recognize the CD."
How can i istall windows server 2000 on Dell Poweredge T300
Windows 2000 is not supported on this machine. The closest you could get is using a hypervisor XenServer or VMWare ESXi and then installing Windows 2000 on a virtual machine.
Jan 26, 2015 | Dell PowerEdge T300 Server
Dell poweredge t300 server e1410 cpu 1 error
The e1410 is an error that is reporting an interruption to the CPU processes. It isn't identifying an issue with the processor specifically, it is just saying its processes were interrupted. Normally when you see the E1410 you will see another error listed with it in the hardware log. Do you see any other errors in the log? Also, what is the BIOS and Drac versions at currently? I ask because the server being very out of date can cause issues like this as well.
Let me know what you see.
Aug 30, 2014 | Dell PowerEdge T300 Server
Open poweredge t300 to replace ram
He shows you how to open the server then you should see the memory.
Apr 11, 2014 | Dell PowerEdge T300 Server
Your corporate Firewall is denying access. I don't know what this site is or does, but you can put in a request to allow access with your IT guy or use it at home.
Jan 20, 2014 | Dell PowerEdge T300 Server
Error code 2900-0325
Use GOOGLE and SEARCH for:
First Search for:
Dell PowerEdge T300 Server list of Error codes
(12,600 hits)
then search for:
Dell PowerEdge T300 Server Error code "2900-0325"
(You will find 40 'hits')
Anthony
Sep 14, 2013 | Dell PowerEdge T300 Server
Configure Dell Poweredge T300 to boot from optical drive
BIOS must see the optical drive. Re-seat / attach drive if it does not. The other option is to use another drive.
Jan 09, 2013 | Dell PowerEdge T300 Server
Error message on server says to call support.
Disassemble Components an Clean the System with Air blower,
& Assemble Components Check it
Aug 26, 2012 | Dell PowerEdge T300 Server
I have blue background and no desktop
I will assume you are trying to connect to another desktop from the server... You may need to setup share properties on the desktop to access it from the network. If you are using VM software on the server and having this issue, you need to reconfigure the VM setting for your user access level.
Good Luck
C2S
Dec 20, 2011 | Dell PowerEdge T300 Server
I have Dell PowerEdge T300 server, running Windows 2003 SP2 after I finished the installation and every thing was ok, and the server reboot many times , the keyboard and mouse stopped working and I can't...
You will need the drivers for them i had a similar problem
insted of reinstalling windows i got a very old taty keyboard and mose from a windows 95 pc
and used them till i got and installed the drivers for them.
Dec 26, 2010 | Dell PowerEdge T300 Server
Nic teaming on poweredge t300
NIC teaming is useless unless you have a switch that support teaming.
However, Dell servers have free lifetime phone support ((800) 945-3355).
They should be able to help.
Jul 26, 2010 | Dell PowerEdge T300 Server
Dell PowerEdge T300 Server   Logo
73 people viewed this question
Ekse
Clive
Clive
