SOURCE: 110V 6ohz - 220V 50hz
Kitchenaid mixers are not recommended on the use of a converter as they are not tested under such conditions. Understanding this, using a convertor on your mixer may automatically void the 1 year warranty regardless of age.
There are international Kitchenaid dealers available if you are requiring 110V. You may contacted Kitchenaid Customer Service for more information.
Their toll-free telephone number is 1-800-541-6390.
SOURCE: I've the 325 watts its 110V kitchen aid and I
You will need a 'step-down' transformer with a rating of at least 500 watts (~500 VA), a primary designed for 220 Volts and a secondary rated at 110-115 Volts.
This type will have four terminals or leads and isolates the input from the output.
There is a non-isolating type called an 'autotransformer' which has one winding with a tap (total of three terminals) roughly in the middle.
I use this type for certain devices but it is not as safe as the first-described type.
If you are living in a foreign country that uses the ~220 Volt standard, you can sometimes get one on 'semipermanent' loan from the local utility.
