When the power button is pressed the power light blinks once as if the tv is on,but its not.there is no picture or audio
The real deal here is the protection circuit has activated. This is
caused whenever an excessive amount of current is being drawn from the
main power supply. Upon detection of same, it immediately takes over
the power management of the set and shuts it down. The clicking sound
you hear is the ON relay turning on the set, but immediately the power
mangement system shuts it OFF. You should hear two clicks, but they
may be so close together that it sounds like one click.
This set is getting rather ancient and I would not recommend you spend
much money on it for this reason: It is highly likely that once the
set if repaired that another failure would occur. This is because of
the law of averages; the first failure is often followed by another
failure from anywhere within the set.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
