Facebook Social Network Logo
R
Ranae Bultman Posted on Jan 20, 2014
Clock is not correct
My clock on my computer is not correct how do I reset?
Mike Kumah
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 20, 2014
Mike Kumah
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
478
Points
8
To reset your clock on your computer, do the following
1.click the START as if logging in, in the opened dialog option, 2.click CONTROL PANEL , in the control panel items locate DATE & TIME, and click on that, Now, you can set your time and date, i hope this help.....have a great day.
Acctim 74172 Radio Controlled Wall Clock. It has been going fine but now it doesn't stay on time. I tried the reset button but it never sets correct time.
Question edited for a lot more clarity, add maker and correct the spelling of 'Duracell'.
Question moved from Radios to Home - Clocks.
With these clocks, you have to make sure you are in the correct Time Zone, and always after battery changes or resets. They are Radio Controlled but not GPS Position Enabled.
https://www.google.com/search?q=74172+radio+manual
Dec 13, 2023 • Home
How duo I change the time on my Sterling & Noble wall clock? It does not have any dials on the back to turn?.
To change the time on a Sterling & Noble wall clock that does not have any dials on the back, you will need to follow these steps:
  1. Locate the small, round hole on the back of the clock. This is the reset button.
  2. Using a small object, such as a paperclip or a toothpick, press and hold the reset button for about 5 seconds. This will reset the clock and allow you to set the time.
  3. Release the reset button, and the minute hand will begin to move around the clock face. Use the reset button to advance the minute hand to the correct time.
  4. Once the minute hand is set to the correct time, the hour hand will begin to move around the clock face. Use the reset button to advance the hour hand to the correct time.
  5. Once the hour hand is set to the correct time, the clock will begin to run normally.
I hope this helps! If you have any further questions, don't hesitate to ask.
WiFi authentication issues
Check the time on your computer's clock in the bottom right corner of the screen (on Windows). Is the clock and date correct? If they are not, then set them to the correct time and date. Hey presto, authentication problems on browser solved.
If your clock keeps needing to be reset every time you start up the machine, then your CMOS Battery is all used up inside the computer and must be replaced by a qualified professional.
How do I set my clock?
I may be able to help but your question is too general/vague. What computer are you using- including manufacturer/make, model number? What operating system are you using (Windows XP, Windows 7, Windows, 8, etc.)? Are you connected to the internet? How long has the computer been on since you had to "reset" it?
2answers
Set computer clock three hours later
Hi buffaloman...
To set your computer clock go to the time in the bottom right hand corner of your desktop screen.
Left click on the clock and a window will open, you will then click on "Date/Time Properties" and it will let you change the time of your computer clock.
Please take time to rate me
2answers
Honda VFR800 Fi 2000 W Reg LCD clock problem
The problem is usually a weak battery. When cranking, it pulls down the system so much that the clock resets. Try puting the batt on a charger and start the bike to see if the clock resets with a steady feed of voltage.
2answers
RCA atomic clock radio didn't reset to DST
Perhaps you've already tried this but on my atomic clock I have to select the DST option and make sure you're in the correct time zone.
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Top Facebook Computers & Internet Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
