The upper looper thread snapped on my very new Janome 6234XL overlocker. I rethreaded using the coloured guide and the manual but the machine will not overlocker or sew - why, what have I done wrong ???? I only rethreaded the snapped thread. Being very new to overlockers I am still on a very steep learning curve - help
You may need to rethread all the threads because most sergers need to be threaded in the right sequence. I looks like this one has to be threaded starting at the right and progressing left.
SOURCE: Help, Janome Ezy Lock 304D Overlocker!
Although the tension units on your machine are of a different configuration, always thread from the right spool first and then each one to the left.........ONLY in that sequence !
now take a look at this sewusa site for a better view of the actual routine through the thread guides.........as I say, the tension units are different, but the sequence is the same, just use the image from above to see which one is next........this chart, just as the one on the fold down cover of your machine need to be followed one thread at a time from R to L
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
SOURCE: thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
SOURCE: lower looper threader
check to make sure it is not wraping around the upper looper. just stitch without the material and you will see it. but then you must rethread the upper looper and the lower looper again in the right order. hope this helps
SOURCE: Owners Manual needed for Overlocker Toyota SL 3404D
"World of Sewing" have these manuals.....you need to ask for "Toyota SL series". I got my replacement manual from them and the service is excellent. Their phone number is online if you want to ring them (UK ) Hope this is helpful to you
SOURCE: Janome mylock 744D overlocker
Have you tried youtube for 'how to' videos? I just found this one that might help. Good luck. http://www.youtube.com/watch?v=JyrAhSQAEeY
