Sony Ericsson HPM-85 Consumer Headphones Logo
Anonymous Posted on May 31, 2009
Brokened hpm85 I owned a HPM85 and recently broked it's stick which connected to it's speaker .So now i want to fix it . Please help me and tell me where can i get it's spare part's in India and there phone number. If you wish to contact me then this is my number 9922255869 Thank you Rijul Pujari
  • Anonymous Jun 01, 2009
    Thanks for your help
Anonymous
Level 2:
Guru:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 93 Answers
  • Posted on May 31, 2009
Anonymous
Expert
Level 2:
Guru:
Mentor:
Answers
93
Questions
0
Helped
33563
Points
189
Hi Mr Pujari
Contact here for Service or Replacement:
Mobile Technology * Brokened hpm85 - pd_icon_blank.gif pd_icon_servicepoint.gif Brokened hpm85 - pd_icon_blank.gifds/images/pd_icon_blank.gif" alt="pd_icon_blank.gif" class="h_mi" /> Brokened hpm85 - pd_icon_blank.gif pd_icon_blank.gif 1785,Bld no 45,Sangmitra Nagar, Opp YMCA, D. N. Nagar, Andheri (W)
400053 Mumbai
Phone: 26713893 / 9819412373 / 9833585472
Hope this info helpful for you
    Please contact to this number which i have mentioned ,,,and they let you know more about this...
    Thanx
1helpful
2answers
Logitech x530 computer speakers
the card got broke? epoxy it back together for the support and make sure all electrical connections from vol control are jumped from control to good side of board, see if u can find someone who has soldering experience if you dont an easy fix if vol control is not damaged
alternative.... search ebay u may find someone selling those same speahers
What is correct xmission dip stick length?
Not sure on the lenght but if you take the old one to a scrap yard and tell them what transmission it's out of, they should be able to fix you up. Use the old one to double check the length.
Altec Lansing im9 - Audio plays only out of one side
I don't own the im9, but I own the im600 and I have managed to take it apart far enough to fix it. I saw no screws to open the system either, but I saw that the grille was loose, so carefully I took it off using a tweezer with a sharp point (sticking it in the holes is the grille near the edge, using the tweezer as a lever) after some time the grille was off. After that I could take the speakers out etc. Maybe this could help you.
2helpful
2answers
Advent ADE 210C
There is no easy way to tell you this. The smaller speakers usually plug into the large speaker. The large speaker is the sub and has a power source for the other speakers.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
2answers
Brother tripped over cord connected to laptop
Sounds like the wires inside got pulled loose or broke. Replace the speaker wires or check them good for connection.
CANT GET SOUND
This is often caused by a shorted speaker wire. If you have a pinched or loose speaker wire that's touching metal, it will cause the deck's internal amplifier to shut off. If you have a multimeter available, disconnect the deck then check each speaker wire for continuity with the chassis ground wire. If you don't have a meter, you can disconnect all the speakers, then connect them again one at a time. See if you can tell if there's one speaker that kills the deck's output.
2answers
Kenwood VR615 turns itself off at medium volumes
I also have the same problem, it is really annoying... anyone have any ideas.... please help!!
Can I connect a mini plug DIGITAL audio source into these?
Hello bobbobbob, These speakers would work great. First question is: Do you already own these speakers, or would you be buying them? If you already own them, then yes, use them, if not, a more economical solution would be the Bose Companion 2 speakers here: http://www.bose.com/controller?event=VIEW_PRODUCT_PAGE_EVENT&product=companion2_multimedia_index These are about half the price, and have exceptional clarity for someone like your aunt. They also will allow her flat panel TV to plug and play very easily. Please let us know if you need any additional information. Best regards and kudos for helping your aunt out! nightdiver
Top Sony Ericsson Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
