SOURCE: I have a vision fitness treadmill. I turn on the
It sound like either the function pad ( more likely the problem ) or the upper electronics have failed. You will need to call Vision Fitness customer support @ 1-800-335-4348
SOURCE: THE T9500 TREADMILL SEEMS TO SLOW DOWN AND INCREASE IN THE INCLINE ON ITS OWN.
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=AZSMLpXm-tA&feature=related
Please see this videos and make this.Finally you have very strong 2 possibilty:1)Main motor 2) Control Board motor.
see the block diagram attached, and see how the main controller board has 90% aprox function of any treadmills. sincerely. G-d bless you
ernesto cuadra
managua, nicaragua. c.a
1) Test the Speed sensor and adjust the same as intructed in your owner manual 2) Plugin very well the connector and clean. 3)exchange batteries by new one in the display board 4) tight the flexible cord from keypanel vs display board 5) tight the connector from display board vs lower board very well. 6)Now test the main motor if is faulty ( short winding) 7) main motor controllber board is faulty ( test the 115VAC + 5VDc for por supply input coming 8) Power transforner maybe faulty.
See the block diagramm that i Did FOR you kno how the main motor board has aprox 90% of functions of any treadmills. Now you will have strong DIAGNOSTIC, for to measurement the answer Right.
sincerely.G-d bless you.
ERNESTO CUADRA
MANAGUA,NICARAGUA. C.A
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
SOURCE: m tf40 vision fitness treadmill wont change incline or speed only just got today
Please RUN the software calibration for easy diagnose, troubleshooting and fix it.
see the diagram attached.
God bless you
With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START.
(The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen)
If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module.
OK
