2004 Chrysler Pacifica Logo
D
Debbie Dahl Posted on Jan 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 Chrysler Pacifica -- interior lights and dashboard lights do not go off when key is turned off! Also the headlights come on intermittently when the engine is turned off!
Why do athe interior light and the dashboard lights stay on when the car is turned off? Also the headlights come on intermittently as well.
Bill Boyd
Level 3:
Top Expert:
  • Chrysler Master 53,816 Answers
  • Posted on Jan 20, 2014
Bill Boyd
Chrysler Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951487
Points
172802
Check the headlights auto unit for a malfunction
5 Related Answers
Anonymous
  • 323 Answers
  • Posted on Jun 05, 2009
SOURCE: 2004 chrysler pacifica
It is for an oil change mainly and any other service your maintenance manual suggests at the mileage interval. It needs to be reset after each oil change to be accurate.
Anonymous
  • 323 Answers
  • Posted on May 01, 2009
SOURCE: Check Engine Light
If the light isn't flashing, it is safe to drive. If it is flashing, then catalytic converter damage can result. Have a parts store check the codes for you and come back and post the code.
Anonymous
  • Posted on Sep 21, 2009
SOURCE: 2004 Chrysler Pacifica Fluctuating Fuel Gauge Indicator
Hello, the answer to solve this problem is to take it to your nearest chrysler dealer and have them re-flash the updates to the ecu....since 2004, chrysler has had about 4-5 new updates since the date they were manufactured....you need to have the update that followed from your date of man. on your vehicle....They attempted to flash mine to the latest update and didnt work, turns out that they need the re-flash from back when...in order to get the gauage to stop fluctuating.....Hope this helps!!
Anonymous
  • 97 Answers
  • Posted on Jan 27, 2010
SOURCE: 2004 chrysler pacifica check engine light code
The codes are both evap system codes. The only good way to find the leaks is to take it to a shop that has a smoke machine. They will pump smoke into the evap system to find the leak.
Anonymous
  • Posted on Jul 22, 2011
SOURCE: 2007 Chrysler Pacifica having intermittent
2007 Chrysler Pacifica having intermittent fuel gauge problems. Goes from normal to dead/ low fuel. Has full tank. Also, check engine light is on
Why 2004 chrysler pacifica start up and then shut off?
theft light on? key lost programming,fuel pressure wrong after sitting (fuel pump needed)regulator on pump this only occurs after sitting will be fine if you drive shortly after just driving.
2004 pacifica has no power when key is turned off
I still don't understand with the key off the only thing that should work would be the odometer and interior lights
2005 Pacifica dashboard lighting.
My personal suggestion would be to go for these repair catalogs. I know this website www.reliable-store com
that i used to buy them from, and they have pdf online it was very good manual. Go ahead, I bet.
3helpful
3answers
Replaced low beam light buls in 2005 pacifica crysler and lights still wont work. What is the problem
MAKE/MODELS: MODEL/BUILD YEARS:
Chrysler/Pacifica 2005
MANUFACTURER: DaimlerChrysler Corporation
NHTSA CAMPAIGN ID NUMBER: 05V066000 RECALL DATE: March 01, 2005
COMPONENT: Exterior Lighting: Headlights
POTENTIAL NUMBER OF UNITS AFFECTED: 43180
SUMMARY:
Certain sport utility vehicles equipped with Halogen headlamps may experience an intermittent and eventual total loss of headlamp function.
CONSEQUENCE:
The head lights may not operate properly which could result in intermittent or no headlight function. This could impair a driver's visibility, increasing the risk of a crash.
REMEDY:
Dealers will inspect, and replace if necessary, the wiring harness and low beam bulb on both headlamp assemblies. The manufacturer has not yet provided an owner notification schedule for this campaign. Owners should contact DaimlerChrysler at 1-800-853-1403.
NOTES:
DaimlerChrysler Recall No. E04. Customers can also contact The National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-327-4236
My 2005 Chrysler Pacifica makes a ticking sound when I try to start it. Do you think it's the starter or something else?
Leave the door open interior lights on turn key to start if lights go out or real dim. Battery bad or posts dirty. Lights bright starter
5helpful
04 chrysler pacifica dashboard lights stay on & drains my battery
my dash lights stay on after i turn off my van, the fan stays on also the alarm does not work or the keyless entry does not work.
04 Pacifica headlights burning out.
You are gonna have to check current draw on the circuit ith multimeter
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
