Dell M209X Ultra Mobile Projector  Projector Logo
A
Anonymous Posted on Jan 20, 2014
M209x when displaying a document the white background is displaying in yellow
Have a bizhub c550 printer and when printing a plain white document i get a yellow background, What could be the problem?
Sir/Mam, have you replaced the yellow image unit ? Not the yellow toner cartridge. There two seperate units. Also there are on each image unit blue/white nubs that you can pull out and push back in to clean interal image unit parts do that you do not have to pull the image units out just ensure that when done cleaning they are pushed all the way back in. Once the image units are not toner cartridge and there are four of them located below each toner cartridge .
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
White spots on screen on dell m209x projector how do i fix ?
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD200
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
2answers
Change background from black to white
Which operating system ??
Is it for computer background or a program ??..
Make a Black Background White
The desktop appearance of a computer equipped with Microsoft Windows XP, whether PC or laptop, can be customized easily.
Users can change background color, background image, frame color, font size and the arrangement of desktop icons.
Five easy steps how to change the desktop background color from black to white.
Changing Background Color
Right-click the mouse on any open portion (i.e., non-icon) of the desktop, which will open a menu. Select "Properties" at the menu's bottom, which will open the "Display Properties" application.
Click the "Desktop" tab at the application's top.
Click the down arrow next to the "Color" button, and select the white color.
Click the "Apply" button, then click "OK" to close the application.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_background_color.mspx?mfr=true
All of my copies and scans have a yellow background. This does not happen when I print a document directly.
You might be scanning and copying in full color even for regular documents. When you do this, it treats the document as a photograph or color document and therefore, the background, even if white, is scanned in as a bit yellow
1helpful
2answers
Is there a way to copy a document that has text on a colored piece of paper and have the background show up white and the text show up black instead of the background being grey and the text being black?
If the background color is light (yellow for example) you can probably play with the contrast and density settings to make it better, but otherwise you can't, unfortunately.
Display background color
Check your MS Windows System colors
Most likely that is the cause of the problem.
26helpful
Adobe acrobat checker board like watermark
If you see a grey and white 'checkerboard' background, you're seeing the background designed to show you the transparency of items in your document.
Select: Edit > Preferences > Page Display then un-check: "Show Transparency Grid."
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
