Pioneer EQ-6500 9-Band Car Equalizer Logo
Posted on May 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power supply connection for pioneer eq-6500
Recently acquired a second-hand Pioneer EQ-6500 9-Band Graphic Equalizer. Cannot locate the original power connection. There are four small slots on the back at the power source, Would like to know which of these relate to ground, power, remote etc. Thank-you
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3721
Points
25
Top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
Anonymous
Level 3:
  • Master 578 Answers
  • Posted on Aug 07, 2009
Anonymous
Master
Level 3:
Answers
578
Questions
0
Helped
237589
Points
1444
IF THOSE SLOTS SAY HIGH IN PUT DONT USE SHOULD TELL U AT THE BACK WHAT WIRE GOING INTO WHICH SLOT
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email [email protected]
2helpful
1helpful
Equalizer Questions
IT is good to have separate eq from built in, because you can adjust or eliminate that you want to hear. For future problem please visit my site at http://billy-tech.blogspot.com/
3helpful
Need wireing diagram for pioneer deq 7600 4pin plug
I need to see a diagram how or how to setup my equalizer and reverb to my amp all pioneers old stuff sg60 and sg540
Ignorant
POWER SOURCE
REMOTE
12VOLT POWER
GROUND//
AND RCA IN FROM DECK AND RCA OUT FROM EQ TO DECK
That's not how my 6500 came i only had red black and 2 blue wites one from radio and one to the amp
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
