Question about Lexar Electronics - Others
My MacBook Pro OS X 10.9.1 won't read my Lexar Professional 800x 8 GB Compact Flash UDMA 7.
    Sergeant:
  • 376 Answers
Try
http://www.apple.com/macbook-pro/
You most likely will need a different card to be compatible with your MacBook pro. Apple website should be helpful.
Posted on Jun 22, 2014
2 Suggested Answers
SOURCE:
jadiazq
  • 2878 Answers
SOURCE: Shot with Lexar Professional 233x 16 GB compact flash but can't retrieve images.
Connect compact flash to a Windows box. Check Disk with Repair and Fix.
Go to Start > Run (Search). Type cmd ENTER. From the Command Prompt type chkdsk x: /r/f ENTER. X being the drive letter.
Posted on Oct 24, 2012
CONSTANT FLASHING CF LAMP NIKON D300
Am afraid that it is an internal hardware problem. Chances are that the electronic trigger that fires the flash has shorted out and is therefore making the flash work even with the camera off. Since this would involve electronic circuitry and components, use of a DVM and a low wattage soldering iron or even a hot air blower, perhaps your best bet would be to seek the services of a qualified professional. Often even if you can actually open the unit for a look and see of the trigger/flash module, replacement part availability would be a major concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 07, 2008 | Nikon D40X Digital SLR Camera Digital...
You can try using a file recovery software like Bad Copy Pro 4.10.125. It works well for me.
Jan 20, 2014 | Lexar Electronics - Others
I can not update my mac to 10.9
Hard to say without knowing exactly what Mac you have and what specs, but most likely reason would be your system doesn't meet the requirements (From Apple support site) - To install Mavericks, you need one of these Macs:
  • iMac (Mid-2007 or later)
  • MacBook (13-inch Aluminum, Late 2008), (13-inch, Early 2009 or later)
  • MacBook Pro (13-inch, Mid-2009 or later),
  • MacBook Pro (15-inch or 17-inch, Mid/Late 2007 or later)
  • MacBook Air (Late 2008 or later)
  • Mac mini (Early 2009 or later)
  • Mac Pro (Early 2008 or later)
  • Xserve (Early 2009)
Your Mac also needs:
  • OS X Mountain Lion, Lion, or Snow Leopard v10.6.8 already installed
  • 2 GB or more of memory
  • 8 GB or more of available space
Jan 18, 2014 | Apple OS Computers & Internet
Usb storage size went down from 8gb to 4mb
First, download this Toshiba flash drive format tool
http://softadvice.informer.com/Toshiba_Usb_Flash_Drive_Format_Tool.html
and use to format your pen drive again with this software.
Nov 06, 2013 | Computers & Internet
I am running OS X 10.4.11 and would like to upgrade my operating system?
Please provide more information.
To what would you like to upgrade it?
Since OSX Mavericks was just announced, I'm going to assume that's what you're wanting to upgrade to.
Not all Macs can run Mavericks.
Mavericks Capable Macs
Mavericks, like its predecessor Mountain Lion, requires one of the following Macs with at least 2 GB of RAM and 8 GB of available hard drive space:
  • iMac (Mid 2007 or newer)
  • MacBook (Late 2008 Aluminum, or Early 2009 or newer)
  • MacBook Air (Late 2008 or newer)
  • MacBook Pro (Mid/Late 2007 or newer)
  • Mac mini (Early 2009 or newer)
  • Mac Pro (Early 2008 or newer)
If your Mac isn't one of the ones listed above, you won't be able to upgrade.
If you have an iMac, MacBook, MacBook Pro, or Mac mini model that was originally released in Early/Mid 2006, the latest version of Mac OS X your system supports is Snow Leopard.
http://store.apple.com/us/product/MC573/mac-os-x-106-snow-leopard
Oct 23, 2013 | Computers & Internet
Oct 24, 2012 | Lexar Electronics - Others
I just inserted a new 8GB memory card but it tells me ''OUT OF MEMORY'' I tried to format it but still gives me the same message. Why is that and what can I do about it please?
The memory card you are trying to use in the camera is not supported. This camera is an older technology that can not recognize the large 8 GB memory capacity of the card. In fact, the largest approved card your camera will recognize is 1 GB.
The list of approved memory cards was obtained from the Nikon Site directly, and pasted below for your convenience.
Nikon has tested the following cards and approved their use in the Coolpix 5700:
CompactFlash memory cards:
SanDisk SDCFB series 16 MB, 32 MB, 48 MB, 64 MB, 96 MB, and 128 MB
Lexar Media 4× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 8× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 10× USB series 128 MB and 160 MB
Lexar Media 40x USB WA series 256 MB*
Microtech International Digital Flash Film 1GB*
Delkin eFilm 650MB Pro*
Ritz Big Print 8x 256MB* (Edge Code 0E1B)
Microdrive cards:
DSCM-10512 512 MB
DSCM-11000 1 GB
Please rate this reply if it helped you out. Good luck!
Aug 10, 2010 | Nikon Coolpix 5700 Digital Camera
In embroidery mode I insert a card adapter into my machine and all I get is a "communication error" I have a Dynex card reader which works fine on my computer. I also have PQ1 compactFlash adapter that...
The solution was sooo easy.....one of my online embroidery groups suggested to put the card in my Janome and let the machine format it. It took about a minute and did not tell me what it was doing..and It worked! It put two folders on my card, Emb5 and ord#5, and I was to copy the jef files into the Emb5 folder, which I did and bingo! my Janome 9500 read the card and produced a screen with my jef files in it. I am a happy camper....I don't know if this works with all Janome machines but it did with mine.
Thanks for being here to help.
Pepsi lady
Jun 24, 2009 | Janome Memory Craft 9500 Computerized...
Electronics - Others Logo
82 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
Joe Negus
Joe Negus
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
