Whirlpool AWM8121 6th Sense - The washing machine starts, goes through the cycle, however once it gets to Rinse it stops. The Rinse and Door open light blinks constantly. I have tried all cycles, turned it off, having it start again and it does the same thing. Anyone able to assist?
This error code means there is an abnormality.
If the on-off door lock LED on a Whirlpool washer flashes rapidly at the same time as at least one other LED, then this means there is an abnormality.
Try first to reset the machine. You can press and hold the reset button for a couple of seconds, otherwise turn off the power completely (unplug it) for 5 mins.
Dion_wan:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
SOURCE: Washer makes loud rattling noise when spinning
first check to make is to be sure machine is level using a 2ft level ck level side to side and front to rear see if level if not adjust either by adjusting level legs on bottom of machine or using wooden door shims available @ building supply store , if you don't have level use two small clear water glasses with a exact amount of water in each put a line on each glass measure with rule and make sure line is in exactly same spot on each glass fill to line and place one on rear of machine and one on front level till lines match then repeat process side to side
SOURCE: what does F7 mean on a whirlpool 6th sense washing
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
SOURCE: whirlpool 6th sense front load washing machine
I have the same problem. Stops randomly during the cycle and turning off the power for a second re-starts it.
I think it is one of the sensors is faulty - for example the sensor that detects if the load is un-balanced, or if the machine has enough water.
Seems to be a common poblem for these machines.
I'm going to try to find which one later today.
SOURCE: Whirlpool front loaded getting stuck in wash and rinse cycle
You can remove the top cover of the unit and put your hands towards the door lock and just hit fair enough to get release the lock mostly it will open if not means just break the lock and replace it since if you are technician it will be easier for you if not kindly call the technician and do the service
