When i plug it in, i have to twist the cable to get the glowing light to come on. So the connection went bad in the computer. I dont think getting a new ac adapter will work. i don't want to get a similiar used computer and swap out the hard drive. can i get a battery with a charger that connects to an outlet for power?
Its a bad pack why not buy one for $8 and not try to do hacking or worse? why think its not bad,? if you used a voltmeter at the mobo side, you know that it was or was not, ONLY!
i cant see you twist things,?
if the mobo jack is bad, on the mobo
there are only 2 fixes for that.
1: buy a new mobo (or new PC)
2: buy the jack and solder it on your self. or a tech do that.
here:
1: new coin cell RTC battery is first.
2: get the main battery out, the bigone they short and overload, the regulators. and the power pack.
leave the big battery out , work better now???????
3: try a new $8 pack. work ok now.?
4: ok we check the Jack next, at the mobo side. for damage
common this is .. for sure something SO OLD. but is only 6 year old I see. not tool old but no spring chicken sure.
RTC coin on page 53 pdf.
http://h10032.www1.hp.com/ctg/Manual/c02985882
now i look inside for you,. reading your manual for you and
see what./
I see this.
lucky you, the jack is cable'IZED
NOT the direct mobo type.
https://www.ebay.com/itm/DC-Power-Jack-Harness-Cable-HP-Compaq-Presario-CQ60-203NR-CQ60-204NR-CQ60-206US/110962776204?hash=item19d5e5988c:g:I~QAAMXQs~ZRl7Mb
see that.
so if that fails, power is lost.
easy no?/ no power no go.
SOURCE: no power
You sound like you have either a dead power supply inside or a dead motherboard. Best thing is to open it up and test each. replace the culprit.
SOURCE: Hard Drive will not boot in Compaq Presario C700
BIOS checksum errors occurs when either the BIOS chjp is faulty or most likely the BIOS battery is nearly flat and the stored info changes and doesn't match the checksum info.
Replace the battery with a new one, leave the battery out for 1/2 hour before inserting the new battery. The BIOS will be reset to the default settings, you need to configure it again eg, datr and time etc.
SOURCE: Compaq Presario Laptop ERROR CODES
on boot into post select F10 enter the bios - correct boot order to dvd 1st hdd 2nd and fdd as 3rd boot devices - highlight network boot and hit enter then disable boot from network the hit F10 to save and exit unit will boot from dvd unit with recovery dvd disc installed
SOURCE: Compaq Presario CMOS battery removal?
no need to reset the unit if the no power check your charger firts if working or not, use tester if working,.. check the dc jact connector if ok no problem check th regulator some capactor or transestor, chips on board it means the problem is from the boar..
how to know bios problem if then computer is not powering?
check all power connection.....
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen.
Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
