Hello I am using an aurora 16e connected to the computer via AES and PCI cards. Using pro tools 10. I am recording at 88,1 kHz and at 32 bit. All clocks match on the card and the program. I am getting ticks in the recording. If in go to 44,1 the ticks keep happening but at a slower pace. Any ideas? Thank you
SOURCE: 9-16 channels issue
So you have your core card and how many accel cards? Which interface is plugged into your core card? If you want the lynx to be 1-16 in and out the easiest thing to do is to make sure it is plugged in to the core card and your rosetta is plugged into the accel card installed after the core card. As far as I know the power sequence won't change the assignment of the i/o. If you don't want to change where the interfaces are plugged in then you can do it in the i/o setup and save the setup for the way your interfaces are plugged into the computer. If your already plugged into the computer like I said then you will need to check the i/o setup to make sure the i/o setup isn't all scrambled.
