Question about Canon EF zoom lens - 35 mm - 80 mm
Canon 35-80 Error 1 clean your lens - Canon EF zoom lens - 35 mm - 80 mm
    Prodigy:
    An expert who has answered 500 questions.
  • Canon Expert
  • 527 Answers
The usual method is to use a pencil eraser on the contacts on the lens and the camera. Be careful not to get the bits in the lens or camera
Posted on Mar 11, 2016
SOURCE:
When i on my Canon EOS 450D camera it says error 99 turn off and on the camera or re install the battery how can fix this problem
The error 99 code has different sources, to identify it do this:
Remove the Lens, and try shooting at various speed high (1/1000 or more) then at more normal ones 1/15, 1/50 etc.
If you see the error 99 then contact canon this is a problem wit the camera.
In this case contact Canon directly.
If you still don' have the error message, then put back the lens and try shooting at different apertures (for a lens the error 99 correspond with an aperture problem)
try every aperture. If the problem appears then, clean the lens contacts both on the camera and on the lens.
If the problem is still there, contact the lens brand, you certainly have a blocked or sticky aperture.
Hope this helps.
May 19, 2011 | Canon EOS 450D Digital Camera
1000d error code 1
user manual say its a communication problem between the camera and lens. The suggested solution is to clean the contacts.
Jan 18, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I am getting error 1 i have cleaned the contacts i take 1 or 2 shots and the error 1 shows again my other lens works fine
It will be good if you can use a good quality contact cleaner in these contacts to dry wipe off .check with the other lens youhave for the contact postions. If there is any change or distortions.
If not the sensor electronics within the unit can be faulty.
Need to take help from Canon as it is a very delicate issue.
Sep 14, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
I have a Canon EOS, 1000D which I purchased in Feb 09. I have an error message coming up on the screen everytime I take a shot (which doesn't record). The error is a Err 99, "Shooting is not possible. Turn...
I did some digging and found that this error is most often a lens communication error. Are you, by chance using a non-Canon lens?
Try the following:
1. Remove the lens and take a picture without any lens on. If you get an ERR 99, then it is a camera issue and you will need to contact Canon for further troubleshooting or repair (ie. not the lens).
2. If you do not get the error with the lens off, try it with a Canon lens or any other lens. If no error, it is a problem with the original lens.
3. If the error occurs on both lenses, clean the lens contacts both on the lens and the camera (refer to your manual).
Hope this helps.
-Tor
Nov 21, 2009 | Canon Rebel XS / Eos 1000D Digital Camera...
I have a canon eos digital camera. It has error 99 code on it when I try to take a picture
Error 99 can be caused by poor communication between the camera and the lens. Often it can be resolved by doing one of these following fixes:
1) Turn the camera off, remove the lens, replace the lens, turn the camera on.
2) If that doesn't work, turn the camera off and remove the lens. Use a clean pencil eraser to clean the electrical contacts between the lens and the camera body. Hold the lens or camera body "upside down" so that the contacts are facing down as you rub them with the eraser so that any eraser debris falls onto the table rather than falling into your camera or lens. Replace the lens.
If neither of these fix your problem you will need to send the camera and lens in to Canon for repair.
Dec 25, 2008 | Canon EOS 40D Digital Camera
Error 99
Trouble shooting Error 99
1. Solution: Remove and replace the battery.
Power the camera off
  1. Remove the battery.
  2. Wait 15 seconds.
  3. Replace the battery.
  4. Power the camera on.
2. Clean the lens contacts.
Clean the lens contects on the rear portion of the lens with a clean pencil eraser.
  • Mount the lens on the camera.
  • Take a picture.
If the error persists, the camera and/or lens may need be serviced by a qualified Canon Service Technician.
3. Remove the 3rd party accessory.
Please remove the 3rd party accessory and replace it with genuine Canon Accessory.
4. Solution: Remove third party lens and try with Canon EF or EF-S lens.
Remove third party lens and try with Canon EF or EF-S lens This link will bring you to the camera page on Canon's website: More trouble shooting, drivers and downloads http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=11154#DownloadDetailAct Best of luck. Could you please rate this advice. Thanks so much!
Mar 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 Canon 30D
I also had this problem.
Try to remove the battery for more than 1 minute.
Also try to remove the CF-Card for more than 1 minute.
For me this only resolved the problem for 5-10 pictures.
Then I had to remove battery and CF-Card again.
The only real solution for this problem is to give the lens to repair.
Because this problem is caused by a wrong adjustment of the lens aperture.
Dec 08, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Canon digital rebel xt :error 1 message
I agree with dovi. I actually emailed canon and here is what they said and how to do it; Thank you for your inquiry regarding your digital SLRs. We value you asa Canon customer and appreciate the opportunity to assist you, and I'm sorry to hear that you're running into the "error 1" message. From what you mentioned, it sounds like the lens might be having problems communicating with your cameras. One thing you could try is toclean the contact points on your lens and your camera. If you have not done this yet you can do so by turning the camera off, removing the lens, then brushing those copper points on both the lens and the camera body with something like a clean eraser. Should problems continue, I would suggest that you go to a local camera shop and try a different lens. That way you can determine whether the problem is due to the lens or to your cameras. I hope this is helpful Jason
Sep 04, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EF zoom lens - 35 mm - 80 mm Logo
91 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
