How does one do that? I don't have a manual. also what battery do you need? I lost the remote
SOURCE: I cannot set the clock on my Teac MC-DX50i
I've found that I can only set the clock using the remote. Press and hold the 'time set' button on the remote, and using the forward and back buttons on either side of the play button, you can change your clock to a 12 hr or 24 hr time setting. Once that is set, press the 'time set' button and that will switch you to the hour, and using the same forward and back buttons, set that. Repeat the process to set the minutes. Press the 'time set' button again to exit out of if, and you're all set!
If the unit is on, press the STANDBY/ON switch to turn it standby
2 Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. "12" or "24" blinks. If you want to change the hour mode, press the .or/ button.
< If you leave the unit idle for 7 seconds, the time setting mode will be cancelled.
3 Press the TIME SET button once more. The "hour" value blinks.
4 Press the SKIP button (.//) to set the current hour.
5 Press the TIME SET button. The "minute" value blinks.
6 Press the SKIP button (.//) to set the current minute.
7 Press the TIME SET button. The clock starts.
