It is like that on the bottom, of my own door of my oven.
Since new! On the older oven I had, you lifted the door and it's hinges up and out and the door came off to make the old way of cleaning the oven easier - when you put it back on, the door would pull up tight on all sides - new ones' seem to have a gap
The large oven door pull's off , and can also be pused back on the same way , if holding the door about 12" from closing pulled towards you to remove or push down to put back on if you pull it off the hinges it may take two to put it back on again
I had the same problem today I found that you have to extend the hindge enough to have the lock tabs lock into the door to hold the hindge in the extend mode. If the tabs are not back in the door it will continue to snap back. After you lay the door in place be sure to extend the lock tabs back up into the oven side towards the pins that you hindge lay on. WATCH YOUR FINGER TIPS!!!
You don't state the exact model but on every oven I've ever fixed this problem on it's a broken door striker catch.
Depending on your model, the catch will either be in the oven door or in the oven body; usually they're straightforward to replace but on older ovens spares can be almost as rare as dodo ****. Usually what breaks is a hardened tempered metal spring, so when they're not available as spares I can usually visit a local spring making company and get someone to make one up as a one-off using the fragments of the old one as a pattern.
After the catch has been replaced the striker itself (usually a specially shaped pin) may need to be adjusted to engage correctly once more. Undoing the lock nut and screwing it in and out adjusts the depth, and is done after the striker catch has been adjusted side to side or up and down to meet the centre of the striker.
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
