There's a chance that the RAV-210 codes will work: advise the Brand and model(s) to be accessed, I'll give you the codes if you'd like.There's a chance that the RAV-210 codes will work: advise the Brand and model(s) to be accessed, I'll give you the codes if you'd like.
You can't post conmments that contain an email address.
To perform a factory reset on a Yamaha RAV 352 remote for use with an RX-V2500 receiver, follow these steps:
1. Turn on the RX-V2500 receiver using its power button or remote control.
2. On the remote, press and hold the "VCR 1" and "ON/STANDBY" buttons simultaneously. Hold both buttons for about five seconds until the remote's indicator light blinks twice.
3. Release the buttons. The remote control should now be reset to its factory default settings.
4. Test the remote by using it to control the RX-V2500 receiver. Make sure the remote is within range and pointed towards the receiver's IR sensor.
If the factory reset doesn't resolve any issues you're experiencing with the remote control, you may need to try replacing the batteries or consider getting a replacement remote from Yamaha or an authorized dealer.
Please note that the steps provided are based on general instructions for Yamaha remotes, and there might be slight variations in the specific procedure for your RAV 352 model. Consulting the user manual for your specific remote or contacting Yamaha customer support can provide you with more accurate and detailed instructions tailored to your device.
I uploaded the list of remote codes here: RAV331 Remote Codes. I hope this helps- it took me an hour to find the stupid CD that came with my receiver and remote!! As for steps to program: Press the CODE SET button, the LED will blink twice. Then press the input button you want to control (HDMI1, 2, etc...) or the power button down in the TV section at the bottom of the remote. The LED will blink at you again. Then enter the 4 digit code you find in the list of devices and the LED will blink several times to let you know you've set the code. Try powering on/off your device; if it doesn't work, try another code using the same steps!
1. Set the selector dial to the position for controlling the component. (for example, set to "VCR" for a VCR) 2. Press both the VOLUME ^ and v keys at the same time and hold them until the indicator flashes twice. 3. Use the numeric keys to enter the four-digit manufacturer code for the component to be used. Make sure that the indicator flashes twice. NOTE: if the indicator does not flash, repeat step 3 and enter the code again. 4. Try operating the component with the remote controller to check the code entering is successful. If not enter another code for the same manufacturer.
Do any experts know the answer to this question? It has been posted multiple times, but I dont' see any answers! It is a pitiful manual that is provided by Yamaha for this purpose and nothing is intuitive about making this work. If anyone know the answer, PLEASE POST IT!
Here's how I got mine to work. FIRST THING: Once it's programmed, you use the TV function keys at the bottom of the remote for Power On, channel changing, etc. The other keys on the remote don't operate the TV.
1) Press the "code set" button with a pen or straightened paper clip 2) Press the [A] key (next to "V-AUX") 3) Enter the code
Test it by pressing the Power key in the TV section on the remote (NOT the "Source" Power" key or Main power key at the top).
RAV311 WJ40930 US
(1) To program the remote to control a TV, press and hold [TV] for at least 5 seconds. To program the remote to control any other device, press and hold [AV] and the desired input button, (i.e. Press and hold [AV] + (DVD) at the same time for 5 seconds for a DVD player.
(2) Enter the 4 digit code for the device
Is this part of a home theater system, as Yamaha does not list remotes thats part of a package by themself. You can search www.yamaho.com and find something there or at l;east a number you can call
