SOURCE: jet 3 ultra 3 Flashes The left motor has a short
Bad news; probably a short in the primary for the motor. This usually happens when the chair has been driven over unstable terrain, like wet, soggy grass and it bogs down in the muck. Driving it out while seated causes over-amping on the motors as they try to compensate for slipping, etc, and a motor will fry or a fuse will blow, or wiring harness will cook. You can replace the motor gear assembly for about $900.00, or try taking the motor to a rebuilder and have it rewound, which runs a couple hundred and the motor is like new again. Jack the left side up, remove the left wheel (make sure you save the key that fits in the slot on the axle! They get lost easy). unplug the motor and remove the 6 bolts holding the motor to the frame, disconnect the shift mechanism and the motor is free. separate the motor from the gear box and take the motor into the shop, reinstall and test run it. If the gearbox wasn't damaged, it should be good as new.
Good luck
SOURCE: jet 3 ultra it sat for a while charged batteries
That's the battery charger clicking on and off. The charger doesn't run all the time while it is on charge because they are sealed batteries, and can't release the gas caused by charging, so it shuts off to let the chemical reaction slow down to reduce gas.
SOURCE: jet 3 ultra needs new battery, where do you get
you can get them from batteries plus. make sure you look at your current batteries and request the correct volts amps and size.
