Question about RIM Blackberry Curve 8300
Doesn't turn on, Red LED light stays lit
Blackberry doesnt turn on and red light on when connected to charger My blackberry froze on me. I turned it off and when I went to turn it back on all I got was a black screen, but the red led light stays lit. It is not the battery because I have a spare battery and it is doing the same thing when I put that battery in.
  • 846 Answers
Try restoring the blackberry using the blackberry firmware update utility, if the problem persists, it's a logic board issue. there are blackberry repair websites that show you how to do the replacement yourself, otherwise here is a service that can repair any Blackberry Bold, Storm, Pearl, Curve, 8800 for screen, lenses,
track balls, usb ports, waterdamage etc.
The website is: Blackberry Repair
Posted on Sep 26, 2009
    Brigadier General:
  • 7,752 Answers
You need to reflash you OS on to the phone...
you can connect the phone using the usb cable to the laptop/pc/mac that you are using then open your desktop manager (blackberry).....open apploader then click on software update and upload the OS back to the phone this should work...it has for every phone i fix that just have a red led blinking...also if the DM does not see your PIN, remove the battery from the phone then connect it again you should see BB PIN:UNKNOWN just click next and you should be good to go.
Posted on Jan 30, 2010
SOURCE:
Ideas Arlec PS906 mobility chair charger. It's saying that battery's charged, only on with one red light when charger off, all lights on when charger attached. It turns on but lowest of power, Elaine
Hi again I'm a bit confused a PsS906 arlec charger is a 12 volt charger ??? Can u supply more information .cheers Hi when u turn charger on red ( led ) should come on / when connected to battery / red & yellow ,( led ) should b on /it's in charging mode /when green ,,( led ) turns on battery is charged.cheers
Dec 09, 2017 | Health & Beauty
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
My blackberry torch isnt turning on. when i remover my batterry then put it back, the led light becomes red for like 3sec then nothng and the screen stay black! what can i do?? my blackberry is only 2...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 24, 2011 | RIM BlackBerry Torch Cell Phone
Silver Sylvania smp2012 2gb what kind of charger do I need for this mp3 player
No separate charger is required. Use a USB cable to connect it to any computer (desktop or portable), or to any powered USB hub. It should charge in about 5-20 minutes. While charging, both the red and green LEDs are lit. When fully charged, the green LED turns off and only the red LED is on.
This device should also be possible to charge using a stand-alone USB power source, such as those used to charge Blackberries.
Aug 14, 2010 | Sylvania SMP2012SL 2GB MP3 Player
Battery #1 terminal lights red and stays red.
Disconnect the - lead from that battery, Repower the charger. The LED should be green. If it stays RED, charger defective.
Reconnect the - lead to the battery, measure voltage when charger is on. Should be between 11.5 and 13 volts. If OK, replace the battery. If lower than 11.5, check for charger cable connections OR for a connected load ( power drawing ) of more than 10 amps.
Sep 20, 2017 | Guest 2631a 30 Amp Battery Charger
My 8520 curve just shut off and will not power up. Full charge, phone 1 week old
My Blackberry 8520 just shut itself down and when I try to turn it back on nothing happens but when I put it into the wall charger the red LED light comes on and a charging symbol but still doesnt switch on.
Ive tried of mulitiple occasions taking out the battery and rebooting it but still no sign of any life?
Any Idea's?
Feb 12, 2010 | RIM BlackBerry Curve 8520 Smartphone
Blackberry 8100 shutting off & turning on
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
then, download and install the latest Handheld Software for your model then open DM and run the application loader once the USB cable is connected to the device. Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=1905AEDAB9BF2477EDC068A355BBA31A&dl=89511F30EDAF2A957D19D07C35FF8B6F
Just fill out the form and the download is free for you.
Oct 01, 2009 | RIM BlackBerry Pearl 8100
My blackberry pearl 8100 wont turn on
I have an answer for the 3-2 red light blink w/black screen. Remove the battery, hold the end call button and put the battery back in. The red light should stay on for a while now. Push and hold the call button and alternate with the end call button untill the hourglass shows. Allow some time to boot up. I stumbled upon this, so if this doesnt work, try simmilar procedrues. I did get mine to work. Good Luck, dont give up, it flashes that 3-2 code for a reason.
Mar 09, 2008 | RIM BlackBerry Pearl 8100
RIM Blackberry Curve 8300 Logo
1,652 people viewed this question
Top RIM Computers & Internet Experts
Otman Lahlou
Otman Lahlou
Ekse
Vincent G
Vincent G
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
