Western
Digital is usually given a choice, do not put the jumper to set the
disk to a single drive / master, or you can refer to the stickers that
were pasted on the hard disk
Western
You need to set up the second drive as a slave, this is done with jumper settings, if you look on the bottom of the hard drive you will see the settings required for the jumper.
You should attach two hard drives on primary ide. Set both jumpers to cable select ( or one on end is master, middle one is slave). The one at the end of the cable is where your o/s should be. You could try putting the third on seconday, along with your dvd rom.
what u can utilize on your tx-sr304 is the optical input at the back of the receiver. connect an optical cable from your PS3 into the receiver then follow these steps: *make sure that the digital input on the front panel of your receiver matches where you placed the optical at the back of the tx-sr304 (either OPT1 or OPT2) *all you have to do is keep pressing the digital input at the front panel until it goes to OPT1 or OPT2 (preferrably stay on DVD mode) AFTER completing this go to your PS3 settings: go to settings / then go to sound settings / then audio output settings / then set it to DIGITAL OUT (optical)/ then play and enjoy.....ü
