Cars & Trucks Logo
s
stefan stadie Posted on Jan 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a dodge ram van 2500 1999when i hold the gas the dodge sarts jerking accelerating.spark plugs, kabel and so on are new!no bug in the computer...is ist the transmission???sorry for my bad english...
Vincent G
Level 3:
  • Cars & Trucks Master 2,363 Answers
  • Posted on Jan 19, 2014
Vincent G
Level 3:
Answers
2363
Questions
Helped
1032042
Points
5917
Check motor mounts and transmission mount
Also check the air tube (TOP AND BOTTOM) for hairline crack.
A worn motor mount can cause excessive vibration and damage the air inlet tube.
5 Related Answers
Anonymous
  • Posted on Nov 24, 2008
SOURCE: What is the order to plug the spark plug wires into the distributor cap on a 1996 dodge ram van 1500 with V6 3.9 liter engine?
I used this firign order on my 95 dodge ram van 3500, 5.9 liter and it seems to run fine.
fireing order 1,8,4,3,6,5,7,2
Cylinder numbered starting at the front of the engine left side 1,3,5,7 right side 2,4,6,8
Don forgetto find the # 1 on the rotor cap.
Anonymous
  • 166 Answers
  • Posted on Jun 12, 2009
SOURCE: need a spark plug wiring diagram 1997 dodge ram 2500
googel it
fordexpert
  • 5692 Answers
  • Posted on Aug 18, 2009
SOURCE: Jerking on normal acceleration.
You might try a TPS switch. It should set a code but yours did't. The throttle position sensor sets the spark advance and fuel flow to match. The other possibility is the EGR system which also should set a code.
If you have not changed the fuel filter,try that because if you accellerate hard the fuel slooshes to the back of the tank.
In normal driving the contaminents lay on the bottom of the tank.
steve noel
  • 750 Answers
  • Posted on Sep 28, 2009
SOURCE: I have an 2002 Honda Odyssey. hesitates at 45-55mph
change fuel filter, check fuel flow and preasure.
Anonymous
  • 22 Answers
  • Posted on Oct 10, 2009
SOURCE: my van just died on me, no spark. I replaced
did you check the crank sensor?
I need a 1984 Dodge Ram van 250 spark plug wire diagram
So what you need to do is type in photos of a 1984 Dodge ram van spark plug and then look at the photos because i cant send a pic on here.
Bucking and Jerking upon acceleration
Check the oil level, coolant level, transmission level. Check water pump, spark plugs,when did you buy the van check see if the car got accidents car fax.com. Also do you speed a lot excessive speed can age your vehicle very fast especially you travel thousand miles and if use it to go to work. Go back to the dealer so you can get write off on the job than file a suit if proof of neglect some dealers are lazy too check the problem there are good and bad mechanics so check Better Business Bureau and National Cars Association for good dealers and reputable private mechanics you may can sue, but you can a lot of money big dealer mechanic for your own protection.
Ford escape wont accelerate and jerks into gear
try checking fireing order of spark plugs sounds like some wires may be on the wrong plugs if this was helpful please give me a good review
Engine misfires and hesitation
Ignition Wires on wrong
Worn out Cats --can't test?
140,000 miles & 11 years--replace them
Check Fuel pressure
Front O2 Sensors--not the issue, but get
changed at 100,000 miles
2000 318 ram van wont start new ecm sensors got spark gas
If you are getting spark to the plugs and fuel spray, and you have compression and the spark is at the right time, you should have explosion.
Is it possible the valve timing is off - timing chain issues ?
Are the new plugs fuel-fouled ?
2answers
My Van starts to cut out after it gets warmed up or going up a hill, like it is starving for gas
You may try a new air filter and perhaps have your intake cleaned. Now is it "jerking" on you? Perhaps at a stop light when the brake is applied. You may want to address the spark plug wires and plugs.
2answers
What does chacoal canister do 1996 dodge ram step accelerator to floor andengine misfires
the charcoal canister is an emissions device that helps to trap high emissions
My 2000 dodge ram 1500 van 5.2 litre as I am driving it will die
If you don't do much highway driving with your van you may have a carbon build up try some fuel njctor cleaner and mid grade gas for a tank or two If you go with the fuel additive rev your engine and watch for moisture and carbon from your exhaust contine to do this till exhaust is clear do not over rev ie do not hold it to the floor press he accelerator pedal and release
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
