Door hinge
SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Sagging microwave door
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
If the door seal is damaged or out of alignment, there is a chance of leakage, which can cause burns, damage to the oven or even a fire hazard.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
SOURCE: How do you replace the lamp in a Kitchenaid
open the top cover then you can see the bulb on the right side of the oven, just remove the lamp and replace it by a similar one. you can try to get the lamp from any electrical shop with the same size and same rating.
SOURCE: microwave oven door heavy
If one of your door springs has failed, you will need to replace both, as well as any associated hardware that has failed.
You can find
links to helpful exploded view diagrams and part ordering help
here.
