As you will have noticed, you cannot open the end of a Bernina 1030.
There are
two light bulbs on this machine, visible on either side of the needle bar and presser foot shaft. Viewed from the rear of the machine, you can see the one on the right but the one on the left is beneath a transparent plastic cover that slides out easily (but does not come right out).
To remove either of the bulbs, which are a bayonet fit, open the accessories box attached to the rear of the machine and take out the screwdriver tool from the top row, on the left hand side by the bobbin storage. One end of the screwdriver is a screwdriver (!) and the other end has a plastic tube - this is designed to grip the bulb.
Place the plastic tube on the end of the bulb, push a little and rotate anti-clockwise about a quarter of a turn to release the bulb.
The bulbs are both 6 Volts, 4 Watts.
