Home Logo
Elizabeth Nordquist Posted on Jan 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dunhaven mantel clock
Can't get the clock to run. it takes D batteries and I replaced those but the clock won't move.
UsedClockPartsdotCom
Level 3:
  • Master 277 Answers
  • Posted on Oct 03, 2016
Master
Level 3:
Answers
277
Questions
0
Helped
146988
Points
4537
2answers
I need help getting my Daniel Dakota quartz mantel clock to chime please?
Question edited for clarity and spelling 'danial' > Daniel.
Question moved to a Daniel Dakota category.
Basic information only. But make sure battery contacts are clean and tight and new fresh batteries.
https://www.google.com/search?q=daniel+dakota+mantel+clock+not+chiming
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
2answers
Looking for owner's manual for Seiko QQF142G mantel clock
You should be able to find one on seiko website
Nov 15, 2017 • Home
2answers
Ho do I keep my Dunhaven Mantelclock from gaining time
Watch this interesting video about
Dunhaven Mantelclock www.youtube.com/watch?v=jFcUXJ8iv8g
Feb 06, 2015 • Home
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
The hour and minute hands do not move while the pendulum moves.
This sounds like a quartz clock movement. If your not using Duracell batteries do so.
4helpful
Can set clock but hands don't move when running, why?
is it battery operated? Are they fresh? Are they in correctly?
2helpful
2answers
I have a Strausbourg chime mantel clock. It chime 2 minutes late every 1/4 hour, how do i fix this. Rae
I lost directions to my clock, it takes two double a batteries for the chime but i dont know how to set it.
thanks
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
