Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
orientation.
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
Note:
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera.
1. Turn camera off
2. Insert memory card
3. Turn camera on
4. When the memory card is inserted in the camera,
the [Format card] option appears in the setup
menu
5. Choose Format to format the entire card. Don't choose Quick Format
6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Welcome to Fixya. Getting a card error means that:
* memory card is not yet formatted for camera use * memory card requires cleaning * using a incompatible memory card * camera malfunction
Here are some troubleshooting steps that you can do it by yourself. However if the error message still persist, you should contact your Canon service center.
Memory Card not formatted You have to format the memory card. Some memory card can't be formatted using a PC's, or formatted by another digital camera. I suggest that you have to format the memory card using the camera itself.
Memory Card requires cleaning Use a dry and soft cloth in cleaning the memory card and the memory acrd slot. Using a clean pencil eraser can also be useful in cleaning the memory card but you have to be careful, slightly rub the eraser on the memory card.
Incompatible memory card Please use a compatible memory card
Camera malfunction In this case you have to contact you service center. It will be a big help if you can check if your camera is still under warranty to get a free service.
Please let me know if you have any questions and if this solution was helpful.
All you need to do is:
Camera malfunction
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB All other V-Series Cameras: SD memory cards up to 2 GB EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
Generally there ara two memories in a camera. First one is internal memory but some camera does not have internal memory. Second one is memory card. There are a couple of memory card models are used in cameras. These days SD/SDHC cards getting very famous in the market. According to your settings generally cameras use firstly its internal memory and automatically passes to the memory card. But if there is no memory card in camera then it gives a message that its memory full. You should control if there is a memory card in your camera.
This is a list of the error codes, obviously some aren't of much help but ...
E1
The memory card is not compatible with the DC50
Zoom Camera. Use a compatible card.
E10
Take the camera to your dealer for service.
E11
E12
E13
E14
E15
E16
E17
E20
Reseat the memory card.
or
Replace the memory card with a known good
card.
or
E21
Confirm that the memory card is compatible with
the camera.
or
or
card.
or
E22
or
card.
or
E23
the camera.
or
E24
the camera.
or
card.
or
E25
the camera.
or
card.
or
Confirm first whether the memory card is still good or bad by using a card reader, put the camera memory card into the card reader then connect it to your system, see whether the system will read your card, if the system doesn't read it, it simply implies that memory card is bad and you need to replace it with a genuine memory card, but if it works it implies that the card slot on the camera is bad. so, your either need to service your camera or you replace the memory card. Thanks
