Can I make my Sky remote control my Denon AVR 1603? I can not find a code for it in the book or on line
SOURCE: Denon AVR 1603 goes to stand by mode
It has a blown channel, unless you are good at repairing them I suggest an authorized Denon service center. This Denon not only needs the shorted output transistors replaced, but a few resistors, a couple of driver transistors and a capacitor on the preamp board as well. alot of parts to be replaced. I have repaired about a hundred of these over the last few years and my shop charges about $200 for this repair, other shops should be about the same.
SOURCE: Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
SOURCE: Denon Remote Required
www.encompassparts.com has them but hold on to your hat!
Manufacturer
Part Number
3990949003
Part Number Variations
Description
REMOTE CONTROL RC974 AVR2805
Your Price
$118.29
Detailed Description
n/a
SOURCE: just connected sky via hdmi through denon 3310 and
ensure that HDMI is selected in your sky settings.
you would not need an amp at all just to view sky, only if you were routing sound to say a surround system.
Are you only getting no sound from the tv? or are you getting sound via the amp but not from the tv?
