I need to reset my Nikon D1500 into his factory setting, please help. thanks
You only can do little when you want to "reset" some settings. Like restoring default settings (page 58 of the manual) You can put back the shooting menu (Page 152 of the manual) and reset custom settings (Page 157 of the manual) If something went wrong while updating the firmware, you should try to contact the service centre closest to you.
SOURCE: Reset to factory setting
Remove the battery for 20 mins. Then replace the battery and go to the camera's Menu setting and set the date & time.
SOURCE: Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
SOURCE: how to reset to the factory settings?
turn camera on, turn upper dial to setup, have the display on, use the up/down arrows on the back of the camera to click to RESET ALL, use the side arrow to to click to the reset box, either NO or RESET.
SOURCE: camera settings on a nikon d2x
Hello howzat11,
I'd like to introduce you to your manual via download. The download is 18.5 megs large. Go to page 133 and visit the two button reset page. It's available for download from: http://www.starbatteries.com/index.html. Look at camera manuals and have fun.
Fotobean
SOURCE: how do I reset my Nikon D60 to factory settings?
You will find "reset" in the custom setting menu.
