The fuel pump isn't being shut down , the engine computer isn't seeing a anti-theft system pass word (code) so it disables the fuel injectors . The security light on ? DTC'S - diagnostic trouble code's are stored . Need a factory or professional scanner to read this code's . You could try a by pass of the key an lock cylinder ,but that may not be the problem . Does your key have a resistor pellet on the side of the key > GM VATS Key Resistor Key Security Bypass
defalt phones codes is 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
Your trusted number was probably linked to your first SIM card. Do you still have that SIM card? If so, swap it back in, then disable the software, and swap back to your new SIM. You should then be able to reactivate the software. Be sure to change your trusted number to one not linked to your phone.
The easiest way to get rid of this inferior software is to simply uninstall it off your phone. I too subcribed to this app.and it was a nightmare! Despite putting in the correct security code, the software wouldn't recognise it and kept saying wrong code,when in fact,it was correct! I strongly advise not to install this application!! Google for yourself and see the hundreds of other people that are having the same problems. Good luck to all.
First connect your router to computer with ethernet cable. Then you can access it with following link http://192.168.1.1 or http://192.168.0.1 type user as "admin" and password as "admin" or blank or "password" then go to wi fi security check your WEP code it is your security key to connect wi fi network. Change it and then save settings and restart router. Let me know if you need more assistance. Thanks
